メインコンテンツにスキップ
Fujifilm FinePix HS30EXR Screen Replacement
必要な工具と部品
  1. Fujifilm FinePix HS30EXR Screen Replacement, Frame: 手順 1、 1の画像 1
    • Flip the camera so that the bottom is facing upwards.
    • With the Phillips #00 screwdriver, remove all four screws.
  2. Fujifilm FinePix HS30EXR Screen Replacement: 手順 2、 1の画像 1
    • Flip the camera so that it is now on the right side.
  3. Fujifilm FinePix HS30EXR Screen Replacement: 手順 3、 1の画像 1
    • Flip the camera so that it is now on the left side.
    • Move or remove the flap hiding the camera ports.
    • With the Phillips #00 screwdriver, remove all screws.
  4. Fujifilm FinePix HS30EXR Screen Replacement: 手順 4、 1の画像 1
    • Flip the camera so that it is now on the top side.
    • With a spudger, pry off the highlighted metal piece of the camera.
  5. Fujifilm FinePix HS30EXR Screen Replacement: 手順 5、 1の画像 1
  6. Fujifilm FinePix HS30EXR Screen Replacement: 手順 6、 1の画像 1
    • Pull the LCD screen up and out of the way.
    • With the Phillips #00 screwdriver, remove the screws.
  7. Fujifilm FinePix HS30EXR Screen Replacement: 手順 7、 2の画像 1 Fujifilm FinePix HS30EXR Screen Replacement: 手順 7、 2の画像 2
    • With a spudger, pry off the frame.
    • If the frame does not easily dislodge after a few attempts, ensure that all screws are taken out.
  8. Fujifilm FinePix HS30EXR Screen Replacement, Screen: 手順 8、 1の画像 1
    • Slowly and carefully pull the frame away to have a better view of the inside.
  9. Fujifilm FinePix HS30EXR Screen Replacement: 手順 9、 1の画像 1
    • Peel back (or off) the black tape to expose more of the inside of the camera.
    • Flip the white switch of the highlighted chamber up, and that should unlock the ribbon cable from its compartment.
    • To see if this worked, gently pull the ribbon cable out of the compartment. It should come out without force.
  10. Fujifilm FinePix HS30EXR Screen Replacement: 手順 10、 1の画像 1
    • Now that the ribbon cable is unconnected, pull away the frame to work on.
  11. Fujifilm FinePix HS30EXR Screen Replacement: 手順 11、 1の画像 1
    • Flip the frame component so that the inside is now accessible.
    • With a screwdriver, unscrew all highlighted screws.
  12. Fujifilm FinePix HS30EXR Screen Replacement: 手順 12、 1の画像 1
    • Flip the LCD Screen component so that the bottom half is now accessible.
  13. Fujifilm FinePix HS30EXR Screen Replacement: 手順 13、 1の画像 1
    • Remove the LCD Screen component from its mount.
    • Turn the LCD Screen component so that the right side is now accessible.
  14. Fujifilm FinePix HS30EXR Screen Replacement: 手順 14、 1の画像 1
    • The LCD Screen can now be removed from the LCD Screen Mount.
    • Carefully remove the LCD Screen, as it is attached by another ribbon cable.
  15. Fujifilm FinePix HS30EXR Screen Replacement: 手順 15、 1の画像 1
    • To remove the LCD Screen, flip the switch on the ribbon cable's container that is closest to the ribbon cable (highlighted by the red circle).
    • Carefully remove the ribbon cable from its compartment, and remove the LCD Screen.
    • Position your new LCD Screen onto where the old one was removed from, and reattach the ribbon cable (ensure that the switch is now clamped down; a light tug should not dislodge the ribbon cable).
終わりに
4 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Andrew Scouten
メンバー登録日: 10/22/18
838 ポイント
5のガイドは作成済み
チーム
Baylor, Team S1-G2, Williams Fall 2018 Baylor, Team S1-G2, Williams Fall 2018人のメンバー
BU-WILLIAMS-F18S1G2
4 メンバー
12のガイドは作成済み
コメント 1 件
Ecran de rechange trouvé chez elecok.
Tuto testé, fonctionne aussi pour le Fuji HS20 EXR.
Bravo et Merci à Andrew et aux contributeurs
Bernard MRT - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 56
今までの合計 2,536
