メインコンテンツにスキップ
Fujifilm FinePix HS30EXR Lens Replacement
必要な工具と部品
  1. Fujifilm FinePix HS30EXR Lens Replacement, Frame: 手順 1、 1の画像 1
    • Flip the camera so that the bottom is facing upwards.
    • With the Phillips #00 screwdriver, remove all four screws.
  2. Fujifilm FinePix HS30EXR Lens Replacement: 手順 2、 1の画像 1
    • Flip the camera so that it is now on the right side.
  3. Fujifilm FinePix HS30EXR Lens Replacement: 手順 3、 1の画像 1
    • Flip the camera so that it is now on the left side.
    • Move or remove the flap hiding the camera ports.
    • With the Phillips #00 screwdriver, remove all screws.
  4. Fujifilm FinePix HS30EXR Lens Replacement: 手順 4、 1の画像 1
    • Flip the camera so that it is now on the top side.
    • With a spudger, pry off the highlighted metal piece of the camera.
  5. Fujifilm FinePix HS30EXR Lens Replacement: 手順 5、 1の画像 1
  6. Fujifilm FinePix HS30EXR Lens Replacement: 手順 6、 1の画像 1
    • Pull the LCD screen up and out of the way.
    • With the Phillips #00 screwdriver, remove the screws.
  7. Fujifilm FinePix HS30EXR Lens Replacement: 手順 7、 2の画像 1 Fujifilm FinePix HS30EXR Lens Replacement: 手順 7、 2の画像 2
    • With a spudger, pry off the frame.
    • If the frame does not easily dislodge after a few attempts, ensure that all screws are taken out.
  8. Fujifilm FinePix HS30EXR Lens Replacement, Motherboard: 手順 8、 1の画像 1
    • Slowly and carefully pull the frame away to have a better view of the inside.
  9. Fujifilm FinePix HS30EXR Lens Replacement: 手順 9、 1の画像 1
    • Peel back (or off) the black tape to expose more of the inside of the camera.
    • Flip the white switch of the highlighted chamber up, and that should unlock the ribbon cable from its compartment.
    • To see if this worked, gently pull the ribbon cable out of the compartment. It should come out without force.
  10. Fujifilm FinePix HS30EXR Lens Replacement: 手順 10、 1の画像 1
    • Disconnect the ribbon cable.
  11. Fujifilm FinePix HS30EXR Lens Replacement: 手順 11、 1の画像 1
    • With the Phillips #00 screwdriver, remove all five screws.
    • Remove the metal casing.
  12. Fujifilm FinePix HS30EXR Lens Replacement: 手順 12、 1の画像 1
  13. Fujifilm FinePix HS30EXR Lens Replacement: 手順 13、 1の画像 1
    • Ensure the four ribbon cables are disconnected from the motherboard.
    • Be aware, one is under the black tape.
  14. Fujifilm FinePix HS30EXR Lens Replacement: 手順 14、 1の画像 1
    • Begin desoldering all four highlighted areas.
  15. Fujifilm FinePix HS30EXR Lens Replacement: 手順 15、 1の画像 1
    • Remove the motherboard.
  16. Fujifilm FinePix HS30EXR Lens Replacement, Lens: 手順 16、 1の画像 1
    • Once the motherboard is taken out, with a screwdriver, unscrew all highlighted screws.
    • Take the lens off once it is unscrewed.
  17. Fujifilm FinePix HS30EXR Lens Replacement: 手順 17、 1の画像 1
    • Un-attatch the current lens, and replace it with the new lens.
終わりに
3 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Andrew Scouten
メンバー登録日: 10/22/18
838 ポイント
5のガイドは作成済み
チーム
Baylor, Team S1-G2, Williams Fall 2018 Baylor, Team S1-G2, Williams Fall 2018人のメンバー
BU-WILLIAMS-F18S1G2
4 メンバー
12のガイドは作成済み
コメント 1 件
What is the price for Normal lens for Fujifilm HS30EXR?
khadgarai286 - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 14
過去 30 日: 57
今までの合計 4,416
