はじめに
In order to access the speakers, the back cover of the camera needs to first be removed and the lens needs to be taken out.
必要な工具と部品
Use the Phillips #00 screwdriver to remove the 7 screws on the sides of the camera:
Four 3.95mm Phillips screws located on the bottom of the camera
Two 3.95mm Phillips screws located on the right side of the camera
One 3.95mm Phillips screw located on the left side of the camera
Use the tweezers to grab the speaker (located on left side of the camera) and pull straight up.
Locate the wire running from the speaker unit to the motherboard.
This is where the power plug for the speaker is located.
