メインコンテンツにスキップ
Fujifilm FinePix 4700 Zoom Lens Replacement
必要な工具と部品
  1. Fujifilm FinePix 4700 Zoom Lens Replacement, Back Cover: 手順 1、 3の画像 1 Fujifilm FinePix 4700 Zoom Lens Replacement, Back Cover: 手順 1、 3の画像 2 Fujifilm FinePix 4700 Zoom Lens Replacement, Back Cover: 手順 1、 3の画像 3
    • Use the Phillips #00 screwdriver to remove the 7 screws on the sides of the camera:
    • Four 3.95mm Phillips screws located on the bottom of the camera
    • Two 3.95mm Phillips screws located on the right side of the camera
    • One 3.95mm Phillips screw located on the left side of the camera
  2. Fujifilm FinePix 4700 Zoom Lens Replacement: 手順 2、 1の画像 1
    • Slide open the battery compartment cover with your thumb.
  3. Fujifilm FinePix 4700 Zoom Lens Replacement: 手順 3、 3の画像 1 Fujifilm FinePix 4700 Zoom Lens Replacement: 手順 3、 3の画像 2 Fujifilm FinePix 4700 Zoom Lens Replacement: 手順 3、 3の画像 3
    • Wedge the edge of the spudger between the front and back case, near the corner of the flash.
    • Carefully run the spudger along the right edge of the camera, creating an opening.
    • Insert the spudger into the left side of the camera, above the screwhole. Then carefully run it along this edge.
  4. Fujifilm FinePix 4700 Zoom Lens Replacement: 手順 4、 2の画像 1 Fujifilm FinePix 4700 Zoom Lens Replacement: 手順 4、 2の画像 2
    • Watch out for the orange ribbon that is still attached to the back cover when you lift it up. It is very delicate and might rip.
    • Slowly lift the back cover straight up, lightly jiggling it if necessary.
    • Remove the battery compartment cover.
  5. Fujifilm FinePix 4700 Zoom Lens Replacement: 手順 5、 1の画像 1
    • Gently insert the spudger under the clip holding the orange ribbon. The clip should lift up and the ribbon will slide out.
    • This step will free the back cover from the rest of the camera.
  6. Fujifilm FinePix 4700 Zoom Lens Replacement, Motherboard Unit: 手順 6、 1の画像 1
    • Pull gently when removing the speaker so you don't rip the wire attached to it.
    • Use the tweezers to grab the speaker (located on left side of the camera) and pull straight up.
    • The speaker will still be connected to the motherboard, but it will not be attached to the front case.
  7. Fujifilm FinePix 4700 Zoom Lens Replacement: 手順 7、 1の画像 1
    • Use the tweezers to pull gently on the small orange ribbon, located in upper left hand corner near the flash, to remove the square insert.
  8. Fujifilm FinePix 4700 Zoom Lens Replacement: 手順 8、 1の画像 1
    • Use your fingers to slowly pull the flash straight up.
    • The step may take a little jiggling.
  9. Fujifilm FinePix 4700 Zoom Lens Replacement: 手順 9、 2の画像 1 Fujifilm FinePix 4700 Zoom Lens Replacement: 手順 9、 2の画像 2
    • Do not fully separate the motherboard unit from the front cover. There is still a ribbon attached and it will rip.
    • Slightly separate the front cover from the motherboard unit (which consists of the motherboard, speaker, screen, and battery compartment).
    • Rotate the bottom portion of the motherboard unit (the screen and battery compartment) over the lens unit.
  10. Fujifilm FinePix 4700 Zoom Lens Replacement: 手順 10、 1の画像 1
    • Use your fingers to remove the tripod mount.
  11. Fujifilm FinePix 4700 Zoom Lens Replacement: 手順 11、 3の画像 1 Fujifilm FinePix 4700 Zoom Lens Replacement: 手順 11、 3の画像 2 Fujifilm FinePix 4700 Zoom Lens Replacement: 手順 11、 3の画像 3
    • Be gentle when undoing the ribbon clips. They break easily.
    • Gently stick the spudger under the ribbon clips and lift them up.
    • Use the tweezers to pull both ribbons out of the ribbon clips.
    • The motherboard unit should now be free from the rest of the camera.
  12. Fujifilm FinePix 4700 Zoom Lens Replacement, Lens: 手順 12、 3の画像 1 Fujifilm FinePix 4700 Zoom Lens Replacement, Lens: 手順 12、 3の画像 2 Fujifilm FinePix 4700 Zoom Lens Replacement, Lens: 手順 12、 3の画像 3
    • Use the spudger to push in the white tab on the square circuit board attached to the front case.
    • Use your finger to pull back the black plastic mount on the right side of the circuit board.
    • While holding back the black plastic mount, use the tweezers to gently lift the ribbon attached to the circuit board.
    • The ribbon and circuit board should both detach from the front case.
  13. Fujifilm FinePix 4700 Zoom Lens Replacement: 手順 13、 1の画像 1
    • Use your fingers to pull the lens unit straight up from the front case.
  14. Fujifilm FinePix 4700 Zoom Lens Replacement: 手順 14、 2の画像 1 Fujifilm FinePix 4700 Zoom Lens Replacement: 手順 14、 2の画像 2
    • Use the Phillips #00 screwdriver to remove the two 4.4mm screws holding the metal bracket on the lens.
    • Use your fingers to remove the bracket.
  15. Fujifilm FinePix 4700 Zoom Lens Replacement: 手順 15、 1の画像 1
    • Use the tweezers to lift the orange plastic plate from the upper left hand corner.
終わりに
ある他の人がこのガイドを完成しました。
作成者
7人の作成者と共同で作成されました。
Lawrence Yang
メンバー登録日: 04/04/12
14 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 14-8, Forte Spring 2012 Cal Poly, Team 14-8, Forte Spring 2012人のメンバー
CPSU-FORTE-S12S14G8
5 メンバー
17のガイドは作成済み
コメント 1 件
Hello! Great guide, congratulations indeed! Could you tell me where to find the orange ribbons to replace them? Thanks!
shimei.chihiro - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 10
今までの合計 1,777
