はじめに
In order to access the button circuit board, the back cover of the camera needs to first be removed.
必要な工具と部品
Use the Phillips #00 screwdriver to remove the 7 screws on the sides of the camera:
Four 3.95mm Phillips screws located on the bottom of the camera
Two 3.95mm Phillips screws located on the right side of the camera
One 3.95mm Phillips screw located on the left side of the camera
Use the Phillips #00 screwdriver to remove the two screws on the bracket holding the right side of the button circuit board.
One 3.85mm Phillips #00 screw
One 3.4mm Phillips #00 screw
