メインコンテンツにスキップ
Fujifilm FinePix 4700 Zoom Back Cover Replacement
必要な工具と部品
  1. Fujifilm FinePix 4700 Zoom Back Cover Replacement, Back Cover: 手順 1、 3の画像 1 Fujifilm FinePix 4700 Zoom Back Cover Replacement, Back Cover: 手順 1、 3の画像 2 Fujifilm FinePix 4700 Zoom Back Cover Replacement, Back Cover: 手順 1、 3の画像 3
    • Use the Phillips #00 screwdriver to remove the 7 screws on the sides of the camera:
    • Four 3.95mm Phillips screws located on the bottom of the camera
    • Two 3.95mm Phillips screws located on the right side of the camera
    • One 3.95mm Phillips screw located on the left side of the camera
  2. Fujifilm FinePix 4700 Zoom Back Cover Replacement: 手順 2、 1の画像 1
    • Slide open the battery compartment cover with your thumb.
  3. Fujifilm FinePix 4700 Zoom Back Cover Replacement: 手順 3、 3の画像 1 Fujifilm FinePix 4700 Zoom Back Cover Replacement: 手順 3、 3の画像 2 Fujifilm FinePix 4700 Zoom Back Cover Replacement: 手順 3、 3の画像 3
    • Wedge the edge of the spudger between the front and back case, near the corner of the flash.
    • Carefully run the spudger along the right edge of the camera, creating an opening.
    • Insert the spudger into the left side of the camera, above the screwhole. Then carefully run it along this edge.
  4. Fujifilm FinePix 4700 Zoom Back Cover Replacement: 手順 4、 2の画像 1 Fujifilm FinePix 4700 Zoom Back Cover Replacement: 手順 4、 2の画像 2
    • Watch out for the orange ribbon that is still attached to the back cover when you lift it up. It is very delicate and might rip.
    • Slowly lift the back cover straight up, lightly jiggling it if necessary.
    • Remove the battery compartment cover.
  5. Fujifilm FinePix 4700 Zoom Back Cover Replacement: 手順 5、 1の画像 1
    • Gently insert the spudger under the clip holding the orange ribbon. The clip should lift up and the ribbon will slide out.
    • This step will free the back cover from the rest of the camera.
終わりに
作成者
6人の作成者と共同で作成されました。
Sarthak Patel
メンバー登録日: 04/03/12
10 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 14-8, Forte Spring 2012 Cal Poly, Team 14-8, Forte Spring 2012人のメンバー
CPSU-FORTE-S12S14G8
5 メンバー
17のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 14
今までの合計 1,192
