この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
This guide will instruct camera owners how to take off the outer casing and how to access the red, rubber power button. Once you access the button, you can remove it and replace the button with a new one.
必要な工具と部品
Locate and remove two 6.4mm screws on the bottom of the camera with a Phillips #00 screwdriver.
Look on the inside of the black back casing.
Locate the red, rubber power button.
To reassemble your device, follow the instructions from the "Disassembling Fujifilm Endeavor 100ix Outer Casing" guide in reverse order.
