メインコンテンツにスキップ
FujiFilm FinePix A340 Flash Unit Replacement
必要な工具と部品
  1. FujiFilm FinePix A340 Flash Unit Replacement, Outer Case: 手順 1、 1の画像 1
    • To prevent the danger of electric shock, remove the batteries before continuing to the next steps.
    • Slide the battery cover to the side to release the batteries.
  2. FujiFilm FinePix A340 Flash Unit Replacement: 手順 2、 3の画像 1 FujiFilm FinePix A340 Flash Unit Replacement: 手順 2、 3の画像 2 FujiFilm FinePix A340 Flash Unit Replacement: 手順 2、 3の画像 3
    • Remove five screws from the camera casing using a tri-point Y0 screwdriver.
  3. FujiFilm FinePix A340 Flash Unit Replacement: 手順 3、 2の画像 1 FujiFilm FinePix A340 Flash Unit Replacement: 手順 3、 2の画像 2
    • Grab the case with your hands and slowly pull back the outer casing.
  4. FujiFilm FinePix A340 Flash Unit Replacement, LCD Screen: 手順 4、 1の画像 1
    • Locate the LCD screen and anchoring screw.
    • Remove screw.
  5. FujiFilm FinePix A340 Flash Unit Replacement: 手順 5、 1の画像 1
    • Carefully pull the LCD screen away from the board it is connected to.
  6. FujiFilm FinePix A340 Flash Unit Replacement: 手順 6、 1の画像 1
    • Push both blue switches away from the holding device to unleach lcd ribbon.
    • Be careful when removing ribbon. If you damage it, you will need to replace it as well.
  7. FujiFilm FinePix A340 Flash Unit Replacement: 手順 7、 1の画像 1
    • Carefully detach the ribbon from where it was connected by the blue pins.
  8. FujiFilm FinePix A340 Flash Unit Replacement: 手順 8、 1の画像 1
    • Now that everything has been disconnected from the board, remove LCD screen.
  9. FujiFilm FinePix A340 Flash Unit Replacement, Motherboard: 手順 9、 1の画像 1
    • Remove the two screws holding the circuit board down.
  10. FujiFilm FinePix A340 Flash Unit Replacement: 手順 10、 2の画像 1 FujiFilm FinePix A340 Flash Unit Replacement: 手順 10、 2の画像 2
    • Remove black sticky tape from circuit board and camera case.
  11. FujiFilm FinePix A340 Flash Unit Replacement: 手順 11、 2の画像 1 FujiFilm FinePix A340 Flash Unit Replacement: 手順 11、 2の画像 2
    • Gently pull the circuit board away from the front side of the camera.
    • Be careful when removing assembly as to not break any solder leads or damage lens assembly.
  12. FujiFilm FinePix A340 Flash Unit Replacement: 手順 12、 2の画像 1 FujiFilm FinePix A340 Flash Unit Replacement: 手順 12、 2の画像 2
    • Remove the logic board by pulling straight away from assembly.
  13. FujiFilm FinePix A340 Flash Unit Replacement, Flash Unit: 手順 13、 1の画像 1
    • Locate the flash unit of the camera. It includes the camera's flash and a capacitor.
  14. FujiFilm FinePix A340 Flash Unit Replacement: 手順 14、 2の画像 1 FujiFilm FinePix A340 Flash Unit Replacement: 手順 14、 2の画像 2
    • Unsolder the flash unit at it's three points.
    • Be careful not to damage the circuit board or surrounding parts with the solder iron.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Cody
メンバー登録日: 04/18/10
47 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 7-11, Maness Spring 2010 Cal Poly, Team 7-11, Maness Spring 2010人のメンバー
CPSU-MANESS-S10S7G11
3 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 9
今までの合計 3,918
