メインコンテンツにスキップ
Frozen "Elsa" Singing Doll Battery Replacement
必要な工具と部品
  1. Frozen "Elsa" Singing Doll Battery Replacement, Surgery!: 手順 1、 1の画像 1
    • Carefully arrange Elsa's clothing so her body is accessible.
    • Find the Voice Module inside the toy's body.
    • Using a seam ripper, open Elsa up near the Voice Module.
  2. Frozen "Elsa" Singing Doll Battery Replacement, Retrieve the Voice Module: 手順 2、 1の画像 1
    • Once the seam is ripped, you'll be able to retrieve the Voice Module from inside the toy.
    • The Voice Module is contained inside a small cloth bag -- open it up with the seam ripper.
  3. Frozen "Elsa" Singing Doll Battery Replacement, Disassemble the Voice Module: 手順 3、 2の画像 1 Frozen "Elsa" Singing Doll Battery Replacement, Disassemble the Voice Module: 手順 3、 2の画像 2
    • Carefully pry off the top the Voice Module to expose the electronics inside.
  4. Frozen "Elsa" Singing Doll Battery Replacement, Battery Replacement: 手順 4、 2の画像 1 Frozen "Elsa" Singing Doll Battery Replacement, Battery Replacement: 手順 4、 2の画像 2
    • Carefully remove the worn LR41 batteries from the Voice Module electronics.
    • Replace with new LR41s, obviously!
    • Warning: button batteries are a choking hazard! Dispose of them properly, and away from children.
終わりに
To reassemble Elsa, follow these instructions in reverse order. Except instead of ripping seams, sew them back up.
Be especially careful to sew securely -- loose batteries are a choking hazard.
2 の人々がこのガイドを完成させました。
Dom Santangelo
メンバー登録日: 09/19/16
592 ポイント
3のガイドは作成済み
コメント 1 件
my daughter lost an Elsa like this a long time ago, would you mind sharing the name of this product or where you bought it from? Thanks
Marisol Diaz - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 16
今までの合計 5,628
