メインコンテンツにスキップ
Frigidaire Side-by-Side Refrigerator Ice Maker Replacement
必要な工具と部品
  1. Frigidaire Side-by-Side Refrigerator Ice Maker Replacement, Unplug your refrigerator: 手順 1、 1の画像 1
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
  2. Frigidaire Side-by-Side Refrigerator Ice Maker Replacement, Remove the ice bin: 手順 2、 2の画像 1 Frigidaire Side-by-Side Refrigerator Ice Maker Replacement, Remove the ice bin: 手順 2、 2の画像 2
    • Open the freezer door.
    • Grasp the lower portion of the front of the ice bin.
    • Lift it slightly and pull it out toward the front of the refrigerator.
  3. Frigidaire Side-by-Side Refrigerator Ice Maker Replacement, Unfasten the ice maker: 手順 3、 3の画像 1 Frigidaire Side-by-Side Refrigerator Ice Maker Replacement, Unfasten the ice maker: 手順 3、 3の画像 2 Frigidaire Side-by-Side Refrigerator Ice Maker Replacement, Unfasten the ice maker: 手順 3、 3の画像 3
    • These screws are challenging to reach.
    • Use a 1/4" nut driver to remove the two screws securing the ice maker to the sidewall of the freezer compartment.
  4. Frigidaire Side-by-Side Refrigerator Ice Maker Replacement, Reposition the ice maker: 手順 4、 2の画像 1 Frigidaire Side-by-Side Refrigerator Ice Maker Replacement, Reposition the ice maker: 手順 4、 2の画像 2
    • Rotate the ice maker to the right and lower the front end to access the cable.
  5. Frigidaire Side-by-Side Refrigerator Ice Maker Replacement, Disconnect the icemaker: 手順 5、 3の画像 1 Frigidaire Side-by-Side Refrigerator Ice Maker Replacement, Disconnect the icemaker: 手順 5、 3の画像 2 Frigidaire Side-by-Side Refrigerator Ice Maker Replacement, Disconnect the icemaker: 手順 5、 3の画像 3
    • Locate the ice maker connector near the back of the freezer.
    • Squeeze the release tabs on the connector to release it, and pull it out to disconnect it.
    • You may need to use two hands to do this, one on the rear half and one on the front half of the connector.
    • You can support the ice maker on the ice bin support if you need both hands to disconnect it.
  6. Frigidaire Side-by-Side Refrigerator Ice Maker Replacement, Remove the ice maker: 手順 6、 2の画像 1 Frigidaire Side-by-Side Refrigerator Ice Maker Replacement, Remove the ice maker: 手順 6、 2の画像 2
    • Remove the ice maker from the freezer compartment.
終わりに
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
作成者
1人の作成者と共同作成されました。
Bill Gilbert
メンバー登録日: 06/30/22
38,497 ポイント
261のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
123 メンバー
23,608のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 8
過去 7 日: 42
過去 30 日: 277
今までの合計 3,700
