メインコンテンツにスキップ
Frequency Amplifier Marshall Kilburn Battery Replacement
必要な工具と部品
  1. Frequency Amplifier Marshall Kilburn Battery Replacement, Battery: 手順 1、 3の画像 1 Frequency Amplifier Marshall Kilburn Battery Replacement, Battery: 手順 1、 3の画像 2 Frequency Amplifier Marshall Kilburn Battery Replacement, Battery: 手順 1、 3の画像 3
    • Lay the amp on its side. You should see a small door kept closed with two screws. Turn the amp so the small door faces you.
  2. Frequency Amplifier Marshall Kilburn Battery Replacement: 手順 2、 1の画像 1
    • Using a TR10 Torx Security Screwdriver, remove the two screws from the door.
    • Remove the door.
  3. Frequency Amplifier Marshall Kilburn Battery Replacement: 手順 3、 3の画像 1 Frequency Amplifier Marshall Kilburn Battery Replacement: 手順 3、 3の画像 2 Frequency Amplifier Marshall Kilburn Battery Replacement: 手順 3、 3の画像 3
    • Pull the yellow tab to remove the battery from the amp.
  4. Frequency Amplifier Marshall Kilburn Battery Replacement: 手順 4、 2の画像 1 Frequency Amplifier Marshall Kilburn Battery Replacement: 手順 4、 2の画像 2
    • Carefully disconnect the battery cord from its socket. Carefully pinch the ends of the rectangular battery cord connector that is connected to the machine and gently pull the rectangular portion away from the machine so that it disconnects.
  5. Frequency Amplifier Marshall Kilburn Battery Replacement: 手順 5、 2の画像 1 Frequency Amplifier Marshall Kilburn Battery Replacement: 手順 5、 2の画像 2
    • To reassemble, plug in the new battery cord, and insert the battery pack; have the yellow tab repositioned as in step 3.
終わりに
作成者
6人の作成者と共同で作成されました。
Edith-Marie Roper
メンバー登録日: 01/25/17
104 ポイント
1ガイドが承認済み
チーム
Washington State, Team 1-16, Staggers Spring 2017 Washington State, Team 1-16, Staggers Spring 2017人のメンバー
WSU-STAGGERS-S17S1G16
1 メンバー
1のガイドは作成済み
コメント 1 件
Hi, my marshall kilburn will not charge my batterie, the (LL10) is fried on the platina. So i need a external charger for the battery but there are to many out there, which one do i need considering that i have to keep the original connector so i can connect it again to the kilburn socket. Thank you
Adnan Kasumovic - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 27
過去 30 日: 99
今までの合計 4,220
