メインコンテンツにスキップ
Free Wheelchair Mission GEN 1 Rear Wheel Axle Replacement
必要な工具と部品
  1. Free Wheelchair Mission GEN 1 Rear Wheel Axle Replacement, Rear Wheel Axle: 手順 1、 2の画像 1 Free Wheelchair Mission GEN 1 Rear Wheel Axle Replacement, Rear Wheel Axle: 手順 1、 2の画像 2
    • Attach the 19mm socket wrench to the head of the bolt in the middle of the wheel
    • With the other hand use the 19mm crescent wrench to hold the nut in place
    • While holding the 19mm crescent wrench in place, use socket wrench to unscrew the bolt
    • The Free Wheelchair Mission Multi-Purpose Tool can be used in place of the 19mm socket wrench
    • Remove the wheel from the axle
  2. Free Wheelchair Mission GEN 1 Rear Wheel Axle Replacement: 手順 2、 2の画像 1 Free Wheelchair Mission GEN 1 Rear Wheel Axle Replacement: 手順 2、 2の画像 2
    • Unscrew the nut holding the bolt and wheel together using your hands.
    • It might be necessary to loosen the nut with a 19 mm crescent wrench and the multi purpose tool
    • Repeat step on other wheel
    • Make sure to keep all corresponding nuts and bolts together to prevent mixup when reassembling the axle
  3. Free Wheelchair Mission GEN 1 Rear Wheel Axle Replacement: 手順 3、 2の画像 1 Free Wheelchair Mission GEN 1 Rear Wheel Axle Replacement: 手順 3、 2の画像 2
    • Locate the two baseplates on the back of the wheelchair holding the axle in place
  4. Free Wheelchair Mission GEN 1 Rear Wheel Axle Replacement: 手順 4、 3の画像 1 Free Wheelchair Mission GEN 1 Rear Wheel Axle Replacement: 手順 4、 3の画像 2 Free Wheelchair Mission GEN 1 Rear Wheel Axle Replacement: 手順 4、 3の画像 3
    • Using the pliers to hold the bolt in place, use the 10mm wrench to remove one bolt from the baseplate.
    • Repeat above step on second bolt
    • Repeat the process on the other baseplate, once one baseplate is loose from the chair and frame,
  5. Free Wheelchair Mission GEN 1 Rear Wheel Axle Replacement: 手順 5、 3の画像 1 Free Wheelchair Mission GEN 1 Rear Wheel Axle Replacement: 手順 5、 3の画像 2 Free Wheelchair Mission GEN 1 Rear Wheel Axle Replacement: 手順 5、 3の画像 3
    • Once both baseplates are loosened from the chair, pull the axle off from the wheelchair
    • The axle should come off easily
    • Slide the baseplates off of the axle
終わりに
To reassemble the axle to the wheelchair, follow these instructions in reverse order.
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Mike Sevilla
メンバー登録日: 04/05/13
348 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 14-7, Maness Spring 2013 Cal Poly, Team 14-7, Maness Spring 2013人のメンバー
CPSU-MANESS-S13S14G7
5 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 7
今までの合計 1,494
