メインコンテンツにスキップ
Free Wheelchair Mission GEN 1 Multi-Position Footrest Replacement
必要な工具と部品
  1. Free Wheelchair Mission GEN 1 Multi-Position Footrest Replacement, Multi-Position Footrest: 手順 1、 2の画像 1 Free Wheelchair Mission GEN 1 Multi-Position Footrest Replacement, Multi-Position Footrest: 手順 1、 2の画像 2
    • Attach the extendable footrest bar to the front frame at the desired height
    • Make sure the two bolt holes on the footrest bar line up with two of the holes on the front frame
  2. Free Wheelchair Mission GEN 1 Multi-Position Footrest Replacement: 手順 2、 2の画像 1 Free Wheelchair Mission GEN 1 Multi-Position Footrest Replacement: 手順 2、 2の画像 2
    • Push a flat head bolt through the hole in the frame.
    • Use the 10mm wrench to secure the nut on the other side of the bolt
    • Twist the 10mm wrench counter-clockwise to tighten the nut
    • Attach the three other flat-head bolts and nuts to the remaining holes by using the 10mm wrench
  3. Free Wheelchair Mission GEN 1 Multi-Position Footrest Replacement: 手順 3、 3の画像 1 Free Wheelchair Mission GEN 1 Multi-Position Footrest Replacement: 手順 3、 3の画像 2 Free Wheelchair Mission GEN 1 Multi-Position Footrest Replacement: 手順 3、 3の画像 3
    • Attach the footrest to the footrest bar with the bottom of the footrest pointing upwards
    • Match the footrest wedges up with the holes and push 4 small bolts through the holes
    • The heads of the bolts should fit perfectly through the footrest
    • Tighten the nuts onto the bolts using the 10mm wrench
    • Make sure the nuts are securely fastened but do not tighten the nuts too tightly
  4. Free Wheelchair Mission GEN 1 Multi-Position Footrest Replacement: 手順 4、 1の画像 1
    • Flip the footrest back over and the footrest is now ready for use
    • The footrest may be adjusted into 4 different locations depending on the height and comfort level of the recipient
  5. Free Wheelchair Mission GEN 1 Multi-Position Footrest Replacement: 手順 5、 3の画像 1 Free Wheelchair Mission GEN 1 Multi-Position Footrest Replacement: 手順 5、 3の画像 2 Free Wheelchair Mission GEN 1 Multi-Position Footrest Replacement: 手順 5、 3の画像 3
    • To change the footrest's position, repeat the previous steps but move the footrest bar to the preferred position by lining up the footrest bar with the holes on the sides of the frame
ゴール
ある他の人がこのガイドを完成しました。
作成者
7人の作成者と共同で作成されました。
Mike Sevilla
メンバー登録日: 04/05/13
348 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 14-7, Maness Spring 2013 Cal Poly, Team 14-7, Maness Spring 2013人のメンバー
CPSU-MANESS-S13S14G7
5 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 952
