メインコンテンツにスキップ
Free Wheelchair Mission GEN 1 Lawn Chair Replacement
必要な工具と部品
  1. Free Wheelchair Mission GEN 1 Lawn Chair Replacement, Remove Cushion: 手順 1、 2の画像 1 Free Wheelchair Mission GEN 1 Lawn Chair Replacement, Remove Cushion: 手順 1、 2の画像 2
    • Locate the four straps on each corner of the cushion.
    • Untie each of the straps and remove the cushion from the chair.
  2. Free Wheelchair Mission GEN 1 Lawn Chair Replacement, Remove Axle: 手順 2、 3の画像 1 Free Wheelchair Mission GEN 1 Lawn Chair Replacement, Remove Axle: 手順 2、 3の画像 2 Free Wheelchair Mission GEN 1 Lawn Chair Replacement, Remove Axle: 手順 2、 3の画像 3
    • Turn the chair around and locate the two base plates that hold the axle to the back of the chair.
    • There are two screws on each of the plates that connect the chair to the axle.
    • Hold the nut with the pliers. In the other hand, use the 10mm wrench to remove the screw.
  3. Free Wheelchair Mission GEN 1 Lawn Chair Replacement, Remove Screws From Axle: 手順 3、 1の画像 1
    • Remove both of the screws from each of the axle plates to free the chair from the axle.
    • Make sure too keep track of which bolts belong to certain parts of the wheelchair. You do not want to loose track of where each bolt belongs.
  4. Free Wheelchair Mission GEN 1 Lawn Chair Replacement, Unfasten Brakes: 手順 4、 1の画像 1
    • Locate both of the brakes. They are each located on the front of the chair between the rear tire and the frame.
    • There are two screws connecting each of the brakes to the frame.
    • Remove both of the screws from the frame using the 10mm wrench and pair of pliers.
  5. Free Wheelchair Mission GEN 1 Lawn Chair Replacement, Remove Brakes: 手順 5、 2の画像 1 Free Wheelchair Mission GEN 1 Lawn Chair Replacement, Remove Brakes: 手順 5、 2の画像 2
    • Remove the brakes from the frame.
    • Repeat with the brake on the other side of the wheelchair.
  6. Free Wheelchair Mission GEN 1 Lawn Chair Replacement, Unfasten Front Frame and Castor Wheel: 手順 6、 2の画像 1 Free Wheelchair Mission GEN 1 Lawn Chair Replacement, Unfasten Front Frame and Castor Wheel: 手順 6、 2の画像 2
    • Locate the screws that hold the back frame, chair, castor wheel, and front frame together.
    • There is one screw on each side of the chair immediately above where the brakes are located.
    • Remove both of these screws using the 10mm wrench and a pair of pliers.
  7. Free Wheelchair Mission GEN 1 Lawn Chair Replacement, Separate Chair from Front Frame: 手順 7、 1の画像 1
    • Remove the front frame and each of the castor wheels from the wheelchair.
  8. Free Wheelchair Mission GEN 1 Lawn Chair Replacement, Remove Lawn Chair: 手順 8、 1の画像 1
    • Remove the lawn chair from the back frame by lifting it up.
終わりに
To place a new lawn chair into the wheelchair, follow these instructions in reverse order.
3 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
David Schaeffer
メンバー登録日: 04/19/13
118 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 14-7, Maness Spring 2013 Cal Poly, Team 14-7, Maness Spring 2013人のメンバー
CPSU-MANESS-S13S14G7
5 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 15
今までの合計 1,001
