メインコンテンツにスキップ
Fountain Pen Nib Repair
必要な工具と部品
  1. Fountain Pen Nib Repair, Nib Repair: 手順 1、 3の画像 1 Fountain Pen Nib Repair, Nib Repair: 手順 1、 3の画像 2 Fountain Pen Nib Repair, Nib Repair: 手順 1、 3の画像 3
    • Assess fountain pen nib damage. The nib is the small metal piece at the tip of the pen from which ink flows.
    • Practice caution when removing the nib, as it is sharp and may cut you.
    • Remove the nib by gripping its top with two fingers and pulling away from the body of the pen. Gently grip the top of the nib with your index finger and thumb. Pull the top away from the pen's body to remove the nib.
    • Removing the nib helps to better assess the fraying of the tines, which are the two thin pieces at the point of the nib.
  2. Fountain Pen Nib Repair: 手順 2、 2の画像 1 Fountain Pen Nib Repair: 手順 2、 2の画像 2
    • Press the nib of the pen down onto the flat surface.
    • Gently apply pressure to straighten out the nib.
    • Slowly roll the fountain pen nib horizontally, from left to right.
    • Rolling is the motion of pressing the nib down on a flat surface and moving it back and forth to straighten out any bends.
    • Rolling the nib of the fountain pen fixes flayed/separated tines.
  3. Fountain Pen Nib Repair: 手順 3、 1の画像 1
    • Rotate the nib by 90 degrees.
    • Apply pressure in a style similar to Step 2. Continue to roll the nib, from the tip to base and back.
    • Rolling the nib after rotating it helps to repair bent tines.
  4. Fountain Pen Nib Repair: 手順 4、 1の画像 1
    • Flip the pen over and repeat the process of Step 3.
  5. Fountain Pen Nib Repair: 手順 5、 2の画像 1 Fountain Pen Nib Repair: 手順 5、 2の画像 2
    • Be sure to practice caution when using sharp tools such as the knife!
    • Slide the knife, or thin metal surface, between the two tines on the nib.
    • Slowly move the pen nib up and down the length of the knife in a flossing motion.
    • This action can help correct misalignment.
  6. Fountain Pen Nib Repair: 手順 6、 1の画像 1
    • Apply some simichrome polish onto a towel or rag.
    • Wax the entirety of the nib using the rag; try to avoid the body of the pen.
    • Removing the pen nib again may make this process easier for some fountain pens.
    • Polishing the pen nib helps to increase ink flow.
  7. Fountain Pen Nib Repair: 手順 7、 1の画像 1
    • Allow the polish to dry before using the pen.
    • Optional: Using a dry chrome polishing rag, buff the pen nib to set the polish.
    • Your newly aligned pen is now ready to use!
終わりに
6 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Clayton Braga
メンバー登録日: 02/20/20
238 ポイント
1ガイドが承認済み
チーム
UC Davis, Team S2-G4, Andersen Winter 2020 UC Davis, Team S2-G4, Andersen Winter 2020人のメンバー
UCD-ANDERSEN-W20S2G4
3 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 7
過去 7 日: 79
過去 30 日: 351
今までの合計 13,380
