メインコンテンツにスキップ
Ford Focus Door Interior dome light assembly Replacement
必要な工具と部品
  1. Ford Focus Door Interior dome light assembly Replacement, interior dome light: 手順 1、 2の画像 1 Ford Focus Door Interior dome light assembly Replacement, interior dome light: 手順 1、 2の画像 2
    • Remove the screw cover in the handle housing using a flathead screwdriver.
  2. Ford Focus Door Interior dome light assembly Replacement: 手順 2、 2の画像 1 Ford Focus Door Interior dome light assembly Replacement: 手順 2、 2の画像 2
    • Remove the screw that is holding the handle housing with a T20 Torx screwdriver.
  3. Ford Focus Door Interior dome light assembly Replacement: 手順 3、 2の画像 1 Ford Focus Door Interior dome light assembly Replacement: 手順 3、 2の画像 2
    • Carefully pull the handle housing off.
    • Do not pull too hard. There are wires attached to the back of the housing.
  4. Ford Focus Door Interior dome light assembly Replacement: 手順 4、 3の画像 1 Ford Focus Door Interior dome light assembly Replacement: 手順 4、 3の画像 2 Ford Focus Door Interior dome light assembly Replacement: 手順 4、 3の画像 3
    • Detach the wires on the handle housing with a flathead screwdriver by pushing upwards on the release slot.
  5. Ford Focus Door Interior dome light assembly Replacement: 手順 5、 2の画像 1 Ford Focus Door Interior dome light assembly Replacement: 手順 5、 2の画像 2
    • Remove the cover on the door grip by prying gently with a flathead screwdriver.
  6. Ford Focus Door Interior dome light assembly Replacement: 手順 6、 2の画像 1 Ford Focus Door Interior dome light assembly Replacement: 手順 6、 2の画像 2
    • Take off the inside door panel by removing all screws with a T20 Torx screwdriver.
    • There are nine screws in total: two on the front, three on the outer side, two on bottom, and two on the inner side.
  7. Ford Focus Door Interior dome light assembly Replacement: 手順 7、 3の画像 1 Ford Focus Door Interior dome light assembly Replacement: 手順 7、 3の画像 2 Ford Focus Door Interior dome light assembly Replacement: 手順 7、 3の画像 3
    • Pull the insulation back to access the door handle bracket.
    • Use an X-acto knife if needed.
  8. Ford Focus Door Interior dome light assembly Replacement: 手順 8、 3の画像 1 Ford Focus Door Interior dome light assembly Replacement: 手順 8、 3の画像 2 Ford Focus Door Interior dome light assembly Replacement: 手順 8、 3の画像 3
    • Remove the two screws holding the handle bracket with a T20 Torx screwdriver.
  9. Ford Focus Door Interior dome light assembly Replacement: 手順 9、 3の画像 1 Ford Focus Door Interior dome light assembly Replacement: 手順 9、 3の画像 2 Ford Focus Door Interior dome light assembly Replacement: 手順 9、 3の画像 3
    • Remove the outside door handle by prying gently with a flathead screwdriver to loosen, and then slide it back.
  10. Ford Focus Door Interior dome light assembly Replacement: 手順 10、 3の画像 1 Ford Focus Door Interior dome light assembly Replacement: 手順 10、 3の画像 2 Ford Focus Door Interior dome light assembly Replacement: 手順 10、 3の画像 3
    • Detach the door latch rod from the handle bracket by pulling the plastic end out of the metal loop.
  11. Ford Focus Door Interior dome light assembly Replacement: 手順 11、 2の画像 1 Ford Focus Door Interior dome light assembly Replacement: 手順 11、 2の画像 2
    • Pull the locking rod free from the handle bracket and remove the broken handle bracket.
終わりに
5 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Cassidy
メンバー登録日: 03/21/16
241 ポイント
1ガイドが承認済み
チーム
Michigan Tech, Team 1-11, Lauer Spring 2016 Michigan Tech, Team 1-11, Lauer Spring 2016人のメンバー
MTU-LAUER-S16S1G11
1 メンバー
2のガイドは作成済み
コメント 1 件
Excellent guide. I should have watched the video before disassembly. Actually got part from coastal ford for $40. Same as napa but actual Ford part! And in stock. Thanks Glen
glenthomas784 - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 10
過去 30 日: 53
今までの合計 23,075
