メインコンテンツにスキップ
はじめに
The bag cutter arm is plastic and therefore must be treated as such. It can break if attempted to move with too much force.
  1. Open the device cover as shown in the image.
    • Open the device cover as shown in the image.
  2. Pull on the left side of the handle to release the bar from the holder. Not much force is required for the cutter arm to come loose. If it seems stuck squeeze the main arm sides together, as shown in the second photo
    • Pull on the left side of the handle to release the bar from the holder.
    • Not much force is required for the cutter arm to come loose. If it seems stuck squeeze the main arm sides together, as shown in the second photo
終わりに
Mackenzie Grossgold
メンバー登録日: 2016年04月14日
865 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 34-17, Maness Spring 2016 Cal Poly, Team 34-17, Maness Spring 2016人のメンバー
CPSU-MANESS-S16S34G17
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 134
