はじめに
You will need:
- Screw Driver Philip
- Soldering iron / Heat Gun
- USB Female Type-B Port 4-Pin
- Solder Wire
- *IF NEEDED* Desoldering Tool
必要な工具と部品
The screws we all looking for are on the back of the box.
Use the screwdriver to remove the 8 screws from the back cover.
Use your flashlight to look for the tabs that secure the circuit boards. The tabs should be located on the top inner front part on both the right and left sides.
Be Careful undoing the tabs* You don't need a lot of force!
Use a flat-head screwdriver to undo the tabs. Just slide the screwdriver in from the side, and rotate the screwdriver a bit to undo it.
Once both tabs are undone, you should be able to slide the board out from the front.
Like I said in the last step, slide the board out the front.
Ok, now that the board is free, you can see more of the inner-workings.
Next, look for the soldering points for the USB Type B.
Should be under the Type B USB.....
Next, use a heat gun or soldering iron and remove the port.
After desoldering or just resoldering the new Type-B, just follow the step to open the box backward. If done right everything should be good to go!
2 件のコメント
60 watt or above soldering iron is required. Couldn’t get it to melt with a 30 watt. I worked on a scarlett 2i2 second generation.
Big Krusty - 返信
This is the 1st gen not the second!!
