はじめに
This guide provides instructions for replacing a fluorescent light ballast and may not reflect different florescent light fixture designs. Intermediate multimeter knowledge is recommended to safely measure and confirm voltage, rewire the ballast, and remove electrical components from the ballast. Please contact a certified electrician if you are unsure what to do or do not feel comfortable proceeding.
必要な工具と部品
Turn off the light switch.
Remove light fixture cover according to the manufacturer's instruction guide.
Put the fixture back together by reversing the steps 1-3. Test the light to make sure it works. If it still does not function, contact a qualified electrician.
ある他の人がこのガイドを完成しました。
