メインコンテンツにスキップ
Fluorescent Light Ballast Replacement
必要な工具と部品
  1. Fluorescent Light Ballast Replacement, Ballast: 手順 1、 2の画像 1 Fluorescent Light Ballast Replacement, Ballast: 手順 1、 2の画像 2
    • Shock Hazard. Before starting this procedure, make sure the room's circuit breaker is in the OFF position.
    • Turn off the light switch.
    • Remove light fixture cover according to the manufacturer's instruction guide.
  2. Fluorescent Light Ballast Replacement: 手順 2、 1の画像 1
    • Burn Hazard. Light bulbs may be hot. If light bulbs were turned on, wait at least 10 minutes before proceeding.
    • Remove the light bulbs by gently twisting each bulb counterclockwise.
    • Remove the light bulb from the light bulb socket.
  3. Fluorescent Light Ballast Replacement: 手順 3、 3の画像 1 Fluorescent Light Ballast Replacement: 手順 3、 3の画像 2 Fluorescent Light Ballast Replacement: 手順 3、 3の画像 3
    • Remove center cover to expose the wiring and ballast components.
  4. Fluorescent Light Ballast Replacement: 手順 4、 3の画像 1 Fluorescent Light Ballast Replacement: 手順 4、 3の画像 2 Fluorescent Light Ballast Replacement: 手順 4、 3の画像 3
    • Shock Hazard. Check the fixture for voltage using the non-contact voltage reader according to the device’s instructions.
    • Shock Hazard. After removing wire nuts, do not touch the bare wires.
    • Remove wire nut by twisting it counterclockwise from the hot side (black or red wire) and the neutral side (white wire). Do not untwist wires.
  5. Fluorescent Light Ballast Replacement: 手順 5、 2の画像 1 Fluorescent Light Ballast Replacement: 手順 5、 2の画像 2
    • Make sure both measure wires are not touching anything else at bare portion.
    • Multimeter should measure at 0 volts.
    • Place the red lead on the bare metal of the black or red wire.
    • Place the black lead on the bare metal of the white wire.
  6. Fluorescent Light Ballast Replacement: 手順 6、 1の画像 1
    • Switch room's circuit breaker to ON position.
    • Turn light switch on and repeat step 5.
    • Shock Hazard. Electricity should now running through wires. Only touch wires with multimeter leads.
    • Make sure multimeter reads between 110-125 volts.
    • If the measured voltage is not between 110-125 volts, do not continue. Contact a qualified electrician for further service.
    • Turn off light switch.
    • Change room's circuit breaker to OFF position.
  7. Fluorescent Light Ballast Replacement: 手順 7、 1の画像 1
    • Take note of wire placement or take a picture of the entire fixture to later reference when reconnecting wiring.
  8. Fluorescent Light Ballast Replacement: 手順 8、 1の画像 1
  9. Fluorescent Light Ballast Replacement: 手順 9、 1の画像 1
    • Take a picture of the ballast's data plate or take note of the information on the data plate to make sure you have the correct replacement part.
  10. Fluorescent Light Ballast Replacement: 手順 10、 2の画像 1 Fluorescent Light Ballast Replacement: 手順 10、 2の画像 2
    • Disconnect all wires from the ballast.
    • Use a screwdriver to remove the ballast from the light fixture.
    • If necessary, cut the wires close to the ballast. The cut wires can be re-used later.
  11. Fluorescent Light Ballast Replacement: 手順 11、 3の画像 1 Fluorescent Light Ballast Replacement: 手順 11、 3の画像 2 Fluorescent Light Ballast Replacement: 手順 11、 3の画像 3
    • Use a screwdriver to install the new ballast to the light fixture.
    • Ballast packaging may have a wiring diagram or may be on the ballast itself.
    • Make sure you strip all wire ends with a wire stripper and use ANSI approved wire nuts on all wired connections.
    • Reconnect all wires according to your notes or picture, add wire nuts to bare wire ends and twisting clockwise.
    • Attach center cover over the wiring and ballast components.
    • Screw in light bulb by placing a light bulb in light bulb socket.
    • Gently twist light bulb clockwise until light bulb is firmly in place.
    • Repeat until all light bulbs are firmly in place.
    • Attach light fixture cover over light bulbs according to manufacturer's instruction guide.
    • Move the room's circuit breaker back to ON position.
    • Turn light switch on to make sure the light works.
終わりに
Put the fixture back together by reversing the steps 1-3. Test the light to make sure it works. If it still does not function, contact a qualified electrician.
作成者
6人の作成者と共同で作成されました。
Forrest Jones
メンバー登録日: 02/18/21
193 ポイント
1ガイドが承認済み
チーム
University of Memphis, Team S5-G12, Willis Spring 2021 University of Memphis, Team S5-G12, Willis Spring 2021人のメンバー
UM-WILLIS-S21S5G12
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 9
過去 7 日: 41
過去 30 日: 232
今までの合計 4,214
