はじめに
If the range or hold button is not working properly, they might be jammed from over-use or improperly installed. Both of these buttons are attached, so if you want to replace one of the buttons you must replace both at once. This guide will show you how.
必要な工具と部品
Turn the multimeter so it is display side down.
Lift up the back stand of the device by putting your thumb in the curved well at the bottom of the device, so you have access to the two covered screws below.
Locate the rubber range and hold buttons in the internal assembly. These are found just below the LCD screen on the left hand side.
Remove the rubber range and hold button part with your thumb and forefinger.
ある他の人がこのガイドを完成しました。
