メインコンテンツにスキップ
Fluance RT83 Belt Replacement
必要な工具と部品
  1. Fluance RT83 Belt Replacement, Belt: 手順 1、 1の画像 1
    • Unplug the turntable.
  2. Fluance RT83 Belt Replacement: 手順 2、 1の画像 1
    • Lock the tonearm in place with the tonearm clip.
    • If the tonearm is not locked in place, it could move around and potentially damage the needle
  3. Fluance RT83 Belt Replacement: 手順 3、 1の画像 1
    • Lift the rubber mat and place it to the side.
    • The rubber mat should come off easily, as it is simply resting on top of the metal platter.
  4. Fluance RT83 Belt Replacement: 手順 4、 1の画像 1
    • Unhook the drive belt from the motor pulley.
    • The drive belt is carefully wrapped around the motor pulley, so it is important to unhook it gently.
  5. Fluance RT83 Belt Replacement: 手順 5、 1の画像 1
    • Remove the drive belt from the metal platter.
  6. Fluance RT83 Belt Replacement: 手順 6、 1の画像 1
    • Grab the new drive belt.
    • Wrap the new drive belt around the motor pulley.
    • Note: When reassembling the turntable, don't forget to wrap the new drive belt around the motor pulley.
  7. Fluance RT83 Belt Replacement: 手順 7、 1の画像 1
    • Once your drive belt is hooked around the motor pulley, continue wrapping the drive belt around the entire metal platter.
    • If you are having difficulty wrapping the new drive belt around the metal platter, go very slowly and gently. Patience may be required for this step.
  8. Fluance RT83 Belt Replacement: 手順 8、 1の画像 1
    • Make sure your drive belt is flush against the platter.
    • It is very important there are no twists in your drive belt.
  9. Fluance RT83 Belt Replacement: 手順 9、 1の画像 1
    • Give your metal platter a gentle spin clockwise.
    • When spinning, the platter should continue to spin for a few seconds on its own.
    • If your metal platter is able to spin with the new drive belt attached, you have successfully installed your drive belt.
  10. Fluance RT83 Belt Replacement: 手順 10、 1の画像 1
    • Place the rubber mat back on top of the metal tray platter.
終わりに
Test by playing a record.
作成者
1人の作成者と共同作成されました。
Austin Daniel
メンバー登録日: 09/20/23
181 ポイント
1ガイドが承認済み
チーム
University of North Texas, Team 1-8, Martin Fall 2023 University of North Texas, Team 1-8, Martin Fall 2023人のメンバー
UNT-MARTIN-F23S1G8
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 16
過去 30 日: 33
今までの合計 192
