メインコンテンツにスキップ
Flip-Flop Line Strap Replacement
必要な工具と部品
  1. Flip-Flop Line Strap Replacement, Line Strap: 手順 1、 1の画像 1
    • Use the utility scissors to remove the tip of the broken line strap.
    • Try to remove as much of the broken tip as possible.
  2. Flip-Flop Line Strap Replacement: 手順 2、 1の画像 1
    • Position one 8-inch zip tie underneath the strap line.
    • Head end of the zip tie.
    • Tail end of the zip tie.
    • You can use any color zip tie to match the color of your flip-flop.
    • Zip ties can be purchased from stores such as Walmart, Ace Hardware, and the Dollar Tree.
  3. Flip-Flop Line Strap Replacement: 手順 3、 1の画像 1
    • Fold the zip tie so that the head end is on top of the line strap.
  4. Flip-Flop Line Strap Replacement: 手順 4、 1の画像 1
    • Insert the tail end through the head end to make a loop.
  5. Flip-Flop Line Strap Replacement: 手順 5、 1の画像 1
    • Tighten the loop by pulling on the tail end of the zip tie.
    • Make the loop approximately a half-inch.
  6. Flip-Flop Line Strap Replacement: 手順 6、 1の画像 1
    • Cut off the extra zip tie material.
  7. Flip-Flop Line Strap Replacement: 手順 7、 1の画像 1
    • Pass the metal flat washer through the second 8-inch zip tie.
    • 4.8mm metal flat washer.
  8. Flip-Flop Line Strap Replacement: 手順 8、 1の画像 1
    • Pass the tail end through the hole on the bottom of the flip-flop.
  9. Flip-Flop Line Strap Replacement: 手順 9、 1の画像 1
    • Pass the tail end through the loop of the first zip tie.
  10. Flip-Flop Line Strap Replacement: 手順 10、 2の画像 1 Flip-Flop Line Strap Replacement: 手順 10、 2の画像 2
    • Return the tail end back through the hole.
    • Pass the tail end into the 4.8mm metal flat washer.
    • Turn the flip-flop on its side for a better view.
  11. Flip-Flop Line Strap Replacement: 手順 11、 1の画像 1
    • Push the 4.8mm metal flat washer inside the hole of the flip-flop.
  12. Flip-Flop Line Strap Replacement: 手順 12、 1の画像 1
    • Insert the tail end into the head end.
  13. Flip-Flop Line Strap Replacement: 手順 13、 2の画像 1 Flip-Flop Line Strap Replacement: 手順 13、 2の画像 2
    • Adjust the length of the zip tie to create a snug fit between your toes.
    • Push the loop of the tail into the hole.
    • Pull on the tail end until you're satisfied with the length.
    • Turn the flip-flip over occasionally to check the length of the toe piece as needed.
    • Length of toe piece.
    • This step might take some trial and error.
  14. Flip-Flop Line Strap Replacement: 手順 14、 1の画像 1
    • Push the head end into the hole of the flip-flop.
    • It's okay if the head end does not fit perfectly inside the hole. It will eventually fit deeper into the hole from walking.
  15. Flip-Flop Line Strap Replacement: 手順 15、 1の画像 1
  16. Flip-Flop Line Strap Replacement: 手順 16、 1の画像 1
    • Cut off about a 1-inch piece of heavy duty duct tape.
    • You can use any color heavy duty duct tape to match the color of your flip-flop.
  17. Flip-Flop Line Strap Replacement: 手順 17、 1の画像 1
    • Wrap the 1-inch piece of heavy duty duct tape tightly around the toe piece of the flip-flop.
    • If you don't have heavy duty duct tape, use two pieces of regular duct tape.
終わりに
Your flip-flops are now restored! If you decide that you don't want them, please consider donating them to a local charity organization.
6 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Dominique Hall
メンバー登録日: 01/18/19
505 ポイント
1ガイドが承認済み
チーム
USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2019 USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2019人のメンバー
USFSM-STEWART-S19S1G1
18 メンバー
30のガイドは作成済み
2件のガイドコメント
my faovert flip flops were riped by a cazey man at the swimming pool i saw him waht to do
Toby Robinson - 返信
Awesome. Thank you!
Windogalaz - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 14
過去 30 日: 83
今までの合計 27,679
