メインコンテンツにスキップ
Flip Video Ultra USB connector Replacement
必要な工具と部品
  1. Flip Video Ultra USB connector Replacement, USB connector: 手順 1、 1の画像 1
    • Unlock the battery cover by sliding the switch to the unlock position.
  2. Flip Video Ultra USB connector Replacement: 手順 2、 1の画像 1
    • Remove the battery cover by sliding it down the camera.
  3. Flip Video Ultra USB connector Replacement: 手順 3、 1の画像 1
    • Remove the batteries.
  4. Flip Video Ultra USB connector Replacement: 手順 4、 1の画像 1
    • Slide the black upper casing off from the device.
    • This is a bit hard to get off, so don't be afraid to use a bit of force. There is no lock.
  5. Flip Video Ultra USB connector Replacement: 手順 5、 2の画像 1 Flip Video Ultra USB connector Replacement: 手順 5、 2の画像 2
    • Remove the six 1mm screws from front of the camera with the Phillips Head screwdriver.
  6. Flip Video Ultra USB connector Replacement: 手順 6、 1の画像 1
    • Remove the top casing from the bottom to reveal the inner circuit board.
  7. Flip Video Ultra USB connector Replacement: 手順 7、 2の画像 1 Flip Video Ultra USB connector Replacement: 手順 7、 2の画像 2
    • When removing the back panel, the rubber buttons will become loose and likely fall off the board. This is normal and can easily placed back on the board once finished.
    • Remove the six 1mm screws with the 1 Phillips head screwdriver.
  8. Flip Video Ultra USB connector Replacement: 手順 8、 2の画像 1 Flip Video Ultra USB connector Replacement: 手順 8、 2の画像 2
    • Gently separate the circuit board from the casing.
  9. Flip Video Ultra USB connector Replacement: 手順 9、 2の画像 1 Flip Video Ultra USB connector Replacement: 手順 9、 2の画像 2
    • Remove the three 1mm screws from the USB connector and back casing with the Phillips Head screwdriver.
  10. Flip Video Ultra USB connector Replacement: 手順 10、 2の画像 1 Flip Video Ultra USB connector Replacement: 手順 10、 2の画像 2
    この手順で使用する道具:
    購入する
    • Gently lift the usb connector using the Plastic opening tool.
    • Using tweezers, remove the cord from the motherboard by gently lifting the connector.
    • The connector will be easier to remove if you wiggle the tweezers while lifting.
  11. Flip Video Ultra USB connector Replacement: 手順 11、 1の画像 1
    • Fully remove the USB connector and replace it with the new USB connector.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Nathaniel Ruf
メンバー登録日: 10/18/16
514 ポイント
5のガイドは作成済み
チーム
UMass Dartmouth, Team 5-7, Martin Fall 2016 UMass Dartmouth, Team 5-7, Martin Fall 2016人のメンバー
UMASSD-MARTIN-F16S5G7
3 メンバー
10のガイドは作成済み
2 件のコメント
My USB port broke off so is there anyway I could save my videos that where om there
Corrina Guerrero - 返信
Where do you purchase the replacement usb connector?
DeEtte Moore - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 11
今までの合計 1,048
