Turn off the device and take the batteries out.
Remove metal sticker under the LCD screen with a spudger.
This may require a large force to pry off the glued sticker.
Use the spudger to separate outer shells.
The spudger must be inserted between the shell halves to pry the edges apart.
Slowly work around the outside to separate the halves.
Gently pull out ribbon cable.
If the ribbon cable does not come out easily you may not have fully unlocked the ribbon cable connector in the previous step.
The LCD screen is now removed and can be replaced.
Flip over circuit board so the ribbon connector is facing up.
Remove the 2 stainless steel 3mm screws securing the lens to circuit board with the #00 Phillips screwdriver.
The lens can now be removed and replaced.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
