メインコンテンツにスキップ
Flash and re-install the firmware of TCA Quadrant
    • Download and install the driver package from here.
    • TCA Yoke and TCA Quadrant both use the same driver.
    • Press on the Windows button and type "Firmware Update" into the search.
    • Unplug your TCA Quadrant from USB port if you already have it plugged-in.
  1. Flash and re-install the firmware of TCA Quadrant, Press and hold the indicated button: 手順 4、 1の画像 1
    • Press and hold the button highlighted on the picture.
  2. Flash and re-install the firmware of TCA Quadrant, Connect to PC while holding the button: 手順 5、 1の画像 1
    • Keep holding the button and connect the Quadrant to USB port of your PC.
    • Once connected, wait a few seconds and let go of the button.
    • You must connect directly to USB port of your PC. It will not work if you connect it to USB port of your Yoke.
    • Your TCA Quadrant should show up in Firmware Updater.
    • Press OK on the Firmware Updater and wait for update to complete.
ゴール
作成者
1人の作成者と共同作成されました。
Formica Fusca
メンバー登録日: 08/01/24
2,595 ポイント
15のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 14
今までの合計 190
