Unscrew a total of 6 4.45 mm phillips head screws using a #00 phillips head screwdriver.
There are 2 screws on the left side (when looking at the front of the camera).
There are 3 screws on the bottom
There is 1 screw on the right side
Turn to the bottom of the camera.
Open the memory card cover by sliding the "CARD/BATT." button up, and then pulling the cover to the left.
Start from the battery compartment and remove the back cover.
Caution: Do not tug on the back cover after it is removed. This could tear the ribbon attaching the back cover to the camera body.
Remove the connecting ribbon from the body of the camera using a pair of tweezers.
Use a soldering iron and a desoldering wick to disconnect the wires from the marked locations.
Once the cables are disconnected, you are now ready to install a new motherboard.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
