メインコンテンツにスキップ
Fixing the Automatic Reverse Flipping of a Cassette-to-Aux Adaptor
必要な工具と部品
  1. Fixing the Automatic Reverse Flipping of a Cassette-to-Aux Adaptor, Fixing the Automatic Reverse Flipping of a Cassette-to-Aux Adaptor: 手順 1、 3の画像 1 Fixing the Automatic Reverse Flipping of a Cassette-to-Aux Adaptor, Fixing the Automatic Reverse Flipping of a Cassette-to-Aux Adaptor: 手順 1、 3の画像 2 Fixing the Automatic Reverse Flipping of a Cassette-to-Aux Adaptor, Fixing the Automatic Reverse Flipping of a Cassette-to-Aux Adaptor: 手順 1、 3の画像 3
    • Remove the six screws around the cassette tape box.
    • Place the screws somewhere safe so you do not lose them.
    • Models, screw locations, and screw sizes may vary.
  2. Fixing the Automatic Reverse Flipping of a Cassette-to-Aux Adaptor: 手順 2、 3の画像 1 Fixing the Automatic Reverse Flipping of a Cassette-to-Aux Adaptor: 手順 2、 3の画像 2 Fixing the Automatic Reverse Flipping of a Cassette-to-Aux Adaptor: 手順 2、 3の画像 3
    • Slowly remove the cover of the cassette box.
    • Take a photo of the insides of the cassette box so it can guide when you are reassembling the cassette box.
    • Do not worry if you open the cassette box upside down (shown in 2nd photo) it is easy to correct; simply put the case back on, flip it over (shown in 3rd photo) and pull the new front side off (1st photo again).
  3. Fixing the Automatic Reverse Flipping of a Cassette-to-Aux Adaptor: 手順 3、 2の画像 1 Fixing the Automatic Reverse Flipping of a Cassette-to-Aux Adaptor: 手順 3、 2の画像 2
    • Remove the auto flip mechanism located on the top corner.
    • Do not throw this away; you may have to reinstall it if you want to use a different cassette player.
  4. Fixing the Automatic Reverse Flipping of a Cassette-to-Aux Adaptor: 手順 4、 2の画像 1 Fixing the Automatic Reverse Flipping of a Cassette-to-Aux Adaptor: 手順 4、 2の画像 2
    • Make sure all electrical circuitry and gears that were not removed are in their correct location.
    • Any other gears inside the cassette box, really aren't necessary. So feel free to remove them if the cassette is making too much noise (shown in 2nd photo).
    • Edit 3/14/2019: All cars are different. Many people in the comments have had luck keeping the center gears in the cassette and removing the interface gears. And also vice versa. Play around with it! If you can get it to work, awesome! If not, then try something else. Don't give up until you have your music playing in your car! Cheers!
終わりに
To reassemble your device, follow these instructions in reverse order, but do not replace the gears you removed.
18 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Jonathan Falco
メンバー登録日: 02/24/15
756 ポイント
2のガイドは作成済み
29件のガイドコメント
that $@$* done work all it did was keep swtiching sides even more without the gears in it.............
pvmxfgt - 返信
It might have to do with the stereo in your car. When I made this guide, I was experiencing the problem in my 2000 Nissan Xterra, but my own guide didn’t help. Some stereos are just broken, like mine was. To be completely honest, I had no idea this guide would even work for people, like it is. Sorry it didn’t help fix your problem. I would suggest getting a new stereo installed in your car. If it’s an older car, you may be able to do it <$100 for a decent stereo. Cheers mate!
Jonathan Falco -
Worked perfectly for me, thanks for putting this guide together.
Patrick Osborne - 返信
You’re welcome!
Jonathan Falco -
Worked for me. I used to buy these things new every couple of years. Glad I did not throw all the old ones out
Peter K - 返信
コメントを追加
統計データ:
過去 24時間: 7
過去 7 日: 27
過去 30 日: 170
今までの合計 88,053
