メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
If your refrigerator door is constantly popping open due to a weak seal, then this guide is the perfect place to look. Many people assume that if the door seal is not working, then either the whole door or the entire refrigerator has to be replaced. In reality, its possible that only the seal needs to be replaced, but most of the time simply washing and realigning the seal is enough to fix it. This guide shows a simple way to clean your current refrigerator door seal and reattach it to your door.
  1. Grab a Phillips Head Screw Driver Lift up the door seal and locate the screws underneath that hold the seal in place. Loosen the screws to where they are pretty loose, but not out of their hole. Note To save energy, you can turn off your refrigerator before proceeding to steps 2-6.
    • Grab a Phillips Head Screw Driver
    • Lift up the door seal and locate the screws underneath that hold the seal in place. Loosen the screws to where they are pretty loose, but not out of their hole.
    • Note To save energy, you can turn off your refrigerator before proceeding to steps 2-6.
  2. After all the screws are loose, the door seal should slide off fairly easy. Slowly remove the door seal with your hands by peeling it off the seal's shell. After all the screws are loose, the door seal should slide off fairly easy. Slowly remove the door seal with your hands by peeling it off the seal's shell. After all the screws are loose, the door seal should slide off fairly easy. Slowly remove the door seal with your hands by peeling it off the seal's shell.
    • After all the screws are loose, the door seal should slide off fairly easy. Slowly remove the door seal with your hands by peeling it off the seal's shell.
  3. Thoroughly wash the door seal in Soap and Water Using a paper towel (or regular towel), dry the seal. Note If your seal has cracks in it, you will need to replace it. If this is the case, skip this step.
    • Thoroughly wash the door seal in Soap and Water
    • Using a paper towel (or regular towel), dry the seal.
    • Note If your seal has cracks in it, you will need to replace it. If this is the case, skip this step.
  4. On the side that connects to the refrigerator unit, apply a thin layer of silicon grease. This will improve functionality as well as prevent the seal from cracking in the future. On the side that connects to the refrigerator unit, apply a thin layer of silicon grease. This will improve functionality as well as prevent the seal from cracking in the future.
    • On the side that connects to the refrigerator unit, apply a thin layer of silicon grease. This will improve functionality as well as prevent the seal from cracking in the future.
  5. To reattach the seal,feed the back of the seal behind the white frame. It is easiest to do this by starting at any corner and completing one side at a time. It is easiest to do this by starting at any corner and completing one side at a time.
    • To reattach the seal,feed the back of the seal behind the white frame.
    • It is easiest to do this by starting at any corner and completing one side at a time.
  6. Make sure the white shell is holding the seal in place on all sides. Tighten all of the screws back in place. Tighten all of the screws back in place.
    • Make sure the white shell is holding the seal in place on all sides.
    • Tighten all of the screws back in place.
終わりに
Your refrigerator should now stay shut properly, and the seal should be tightly secured in place. To assure proper functionality, check every once in awhile to make sure the seal is firmly in place.
43 の人々がこのガイドを完成させました。
Curtis Rosol
メンバー登録日: 2015年04月09日
1,451 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 30-5, Green Spring 2015 Cal Poly, Team 30-5, Green Spring 2015人のメンバー
CPSU-GREEN-S15S30G5
5 メンバー
20のガイドは作成済み
10 件のコメント
Love that you show how to fix on a mini fridge! #CollegeLife Thanks for this :)
tcarle1191 - 返信
How can I fix the seals on chest fridge.
Ramon Espinoza - 返信
Thank you for such a great article with the pictures, it is really helpful! I have just looked at my fridge door, lookes like i know how to detach the seal, but… i am afraid i won´t be able to put it back again…)))
AngiGi - 返信
buy a new fridge - i wood- support american union workers
dkp50 - 返信
How much should the GE repairman charge for this repair? My mother-in-law was told it’ll cost her between $250-$275. I think that’s too much due to the cost of the seal. Does the labor cost account for the extra $200?
Raymond Frazier - 返信
コメントを追加
統計データを表示:
過去 24時間: 134
過去 7 日: 771
過去 30 日: 3,745
今までの合計 223,854
