メインコンテンツにスキップ
Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler
必要な工具と部品
  1. Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler, Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: 手順 1、 3の画像 1 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler, Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: 手順 1、 3の画像 2 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler, Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: 手順 1、 3の画像 3
    • Turn your label-maker on its face. Using your thumb, press in and then upward on the fastener located on the side of your device.
  2. Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: 手順 2、 3の画像 1 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: 手順 2、 3の画像 2 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: 手順 2、 3の画像 3
    • Remove the batteries from your device.
  3. Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: 手順 3、 3の画像 1 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: 手順 3、 3の画像 2 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: 手順 3、 3の画像 3
    • Using a plastic opening tool from your iFixit tool kit, leverage the label cartridge out of your device.
  4. Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: 手順 4、 3の画像 1 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: 手順 4、 3の画像 2 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: 手順 4、 3の画像 3
    • Press the label paper back into alignment with the small holders on the right side of the label cartridge.
  5. Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: 手順 5、 3の画像 1 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: 手順 5、 3の画像 2 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: 手順 5、 3の画像 3
    • Place the label cartridge and batteries back into your device. Refasten the bottom case of the label-maker.
  6. Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: 手順 6、 3の画像 1 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: 手順 6、 3の画像 2 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: 手順 6、 3の画像 3
    • Well done! You have successfully corrected the paper-jam in your Brother PT-90 Label-Maker.
終わりに
作成者
4人の作成者と共同で作成されました。
Kaitlyn Abrams
メンバー登録日: 10/13/16
1 ポイント
1ガイドが承認済み
チーム
University of Maine, Team 2-1, Diaz Fall 2016 University of Maine, Team 2-1, Diaz Fall 2016人のメンバー
UMAINE-DIAZ-F16S2G1
3 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 11
今までの合計 816
