メインコンテンツにスキップ
この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
Fixing Wheel Glitch on Mouse Roccat Kone[+] Plus
必要な工具と部品
  1. Fixing Wheel Glitch on Mouse Roccat Kone[+] Plus, Fixing Wheel Glitch on Mouse Roccat Kone[+] Plus: 手順 1、 1の画像 1
    • Unplug mouse.
    • Cover the optical sensor with tape
  2. Fixing Wheel Glitch on Mouse Roccat Kone[+] Plus: 手順 2、 2の画像 1 Fixing Wheel Glitch on Mouse Roccat Kone[+] Plus: 手順 2、 2の画像 2
    • With a heat gun/hair dryer start warming up the covers. This serves to loosen up the glue that keeps the glides attached to the mouse.
    • Once hot, try to gently lift the glide and work the edges. (to reapply it back on heat the gliders but not to hot to burn but to make the the glue soft, then firmly hold it in place till it cools and holds it grip.)
    • Once glidez are removed, screws are in plain sight
    • DO NOT TOUCH OR STAIN THE STICKY PART OF THE GLIDEZ, otherwise they will not stick back.
  3. Fixing Wheel Glitch on Mouse Roccat Kone[+] Plus: 手順 3、 2の画像 1 Fixing Wheel Glitch on Mouse Roccat Kone[+] Plus: 手順 3、 2の画像 2
    • Unscrew all 4 screws.
    • Gently pull the lower and upper part in opposite directions. DO NOT USE FORCE.
    • Lower and upper part are attached by 5 wires
    • You can either leave them attached or unplug the wires using the tweezers
    • I prefered to separate the two parts for better handling of the lower part, where optical sensor and scroll sensor are located.
  4. Fixing Wheel Glitch on Mouse Roccat Kone[+] Plus: 手順 4、 3の画像 1 Fixing Wheel Glitch on Mouse Roccat Kone[+] Plus: 手順 4、 3の画像 2 Fixing Wheel Glitch on Mouse Roccat Kone[+] Plus: 手順 4、 3の画像 3
    • Replug the mouse in its initial USB port.
    • Insert small piece cloth or tissue paper under the mouse wheel to prevent uncontrolled WD-40 leakeges
  5. Fixing Wheel Glitch on Mouse Roccat Kone[+] Plus: 手順 5、 2の画像 1 Fixing Wheel Glitch on Mouse Roccat Kone[+] Plus: 手順 5、 2の画像 2
    • Now spray contact cleaner (ignore WD-40) directly in the space indicated in the picture. Scroll up a couple of times and scroll down a few times while spraying.
    • plug mouse in to PC, you can easily check in real time if it clears up persistent, or vanishes.
    • If this won't fix it, this probably means the scroll sensor is permanently damaged/defective. (RMA?)
  6. Fixing Wheel Glitch on Mouse Roccat Kone[+] Plus: 手順 6、 2の画像 1 Fixing Wheel Glitch on Mouse Roccat Kone[+] Plus: 手順 6、 2の画像 2
    • If the mouse wheel is not sturdy enough for your taste you can easily insert small pices of cropped paper between spaces around the mouse wheel
    • I used small piece of folded sticky note I always keep on my desk. :) No more wiggling mouse wheel.
  7. Fixing Wheel Glitch on Mouse Roccat Kone[+] Plus: 手順 7、 1の画像 1
    • Once the glicth is fixed re-attach the wires and reassemble the lower and upper part together.
    • When reattaching the glidez use same method backwards. Basically apply pressure on the the heated glidez and they should stick back to their place.
終わりに
34 の人々がこのガイドを完成させました。
作成者
12人の作成者と共同で作成されました。
Isip V Nicola
メンバー登録日: 06/14/12
548 ポイント
1ガイドが承認済み
21 件のコメント
####WARNING####
You better stick with the hair dryer when warming up the glue of the glidez.
I just performed this guide and it totally worked out. But I used a heat gun to warm up the mouse glidez. Due to the heat, the plastic that shapes the left mouse button, deformed a bit. The mouse is actually working normal, but you need a significant higher force to push the LMB now.
So be careful about the temperatures when warming the glidez.
Beside this fault of mine, the guide is perfect. Mouse wheel glitch is completely gone.
thx.
mmda81
Michael Ungers - 返信
Thanks for the suggestion, already corrected. :)
Isip V Nicola - 返信
Worked perfect with hair dryer and WD-40 in 15 minutes!
rinaf - 返信
Excellent concise guide. Thank You!!!
brenogrady - 返信
Thanks so much, it worked perfectly on a Roccat Savu. The side buttons were not working anymore after a mouse drop.
Just be patient with the glides & the hair drier.
John Doe - 返信
コメントを追加
統計データ:
過去 24時間: 28
過去 7 日: 145
過去 30 日: 636
今までの合計 68,074
