メインコンテンツにスキップ
はじめに
Although the Roccat Kone[+] represents Roccat's top of the line model in gaming mice category, it has one small weakness within the scroll wheel mechanism. It is very sensite to dust...and after some time it will start to malfunction
In this video you will find a short review of the Kone[+] and the manifestation of the glitch.
Before you atempt to perform this repair make sure the glicth is actually permanent, and make an attempt at fixing it with a few blows with an air compressor.
パーツ
パーツは指定されていません。
  1. Unplug mouse.
    • Unplug mouse.
    • Cover the optical sensor with tape
  2. With a heat gun/hair dryer start warming up the covers. This serves to loosen up the glue that keeps the glides attached to the mouse. Once hot, try to gently lift the glide and work the edges. (to reapply it back on heat the gliders but not to hot to burn but to make the the glue soft, then firmly hold it in place till it cools and holds it grip.)
    • With a heat gun/hair dryer start warming up the covers. This serves to loosen up the glue that keeps the glides attached to the mouse.
    • Once hot, try to gently lift the glide and work the edges. (to reapply it back on heat the gliders but not to hot to burn but to make the the glue soft, then firmly hold it in place till it cools and holds it grip.)
    • Once glidez are removed, screws are in plain sight
    • DO NOT TOUCH OR STAIN THE STICKY PART OF THE GLIDEZ, otherwise they will not stick back.
  3. Unscrew all 4 screws. Gently pull the lower and upper part in opposite directions. DO NOT USE FORCE.
    • Unscrew all 4 screws.
    • Gently pull the lower and upper part in opposite directions. DO NOT USE FORCE.
    • Lower and upper part are attached by 5 wires
    • You can either leave them attached or unplug the wires using the tweezers
    • I prefered to separate the two parts for better handling of the lower part, where optical sensor and scroll sensor are located.
  4. Replug the mouse in its initial USB port. Insert small piece cloth or tissue paper under the mouse wheel to prevent uncontrolled WD-40 leakeges Insert small piece cloth or tissue paper under the mouse wheel to prevent uncontrolled WD-40 leakeges
    • Replug the mouse in its initial USB port.
    • Insert small piece cloth or tissue paper under the mouse wheel to prevent uncontrolled WD-40 leakeges
  5. Now spray contact cleaner (ignore WD-40) directly in the space indicated in the picture. Scroll up a couple of times and scroll down a few times while spraying. plug mouse in to PC, you can easily check in real time if it clears up persistent, or vanishes.
    • Now spray contact cleaner (ignore WD-40) directly in the space indicated in the picture. Scroll up a couple of times and scroll down a few times while spraying.
    • plug mouse in to PC, you can easily check in real time if it clears up persistent, or vanishes.
    • If this won't fix it, this probably means the scroll sensor is permanently damaged/defective. (RMA?)
  6. If the mouse wheel is not sturdy enough for your taste you can easily insert small pices of cropped paper between spaces around the mouse wheel I used small piece of folded sticky note I always keep on my desk. :) No more wiggling mouse wheel.
    • If the mouse wheel is not sturdy enough for your taste you can easily insert small pices of cropped paper between spaces around the mouse wheel
    • I used small piece of folded sticky note I always keep on my desk. :) No more wiggling mouse wheel.
  7. Once the glicth is fixed re-attach the wires and reassemble the lower and upper part together.
    • Once the glicth is fixed re-attach the wires and reassemble the lower and upper part together.
    • When reattaching the glidez use same method backwards. Basically apply pressure on the the heated glidez and they should stick back to their place.
終わりに
28 の人々がこのガイドを完成させました。
Isip V Nicola
メンバー登録日: 2012年06月14日
461 ポイント
1ガイドが承認済み
15 件のコメント
####WARNING####
You better stick with the hair dryer when warming up the glue of the glidez.
I just performed this guide and it totally worked out. But I used a heat gun to warm up the mouse glidez. Due to the heat, the plastic that shapes the left mouse button, deformed a bit. The mouse is actually working normal, but you need a significant higher force to push the LMB now.
So be careful about the temperatures when warming the glidez.
Beside this fault of mine, the guide is perfect. Mouse wheel glitch is completely gone.
thx.
mmda81
Michael Ungers - 返信
Thanks for the suggestion, already corrected. :)
Isip V Nicola - 返信
Worked perfect with hair dryer and WD-40 in 15 minutes!
rinaf - 返信
Excellent concise guide. Thank You!!!
brenogrady - 返信
Thanks so much, it worked perfectly on a Roccat Savu. The side buttons were not working anymore after a mouse drop.
Just be patient with the glides & the hair drier.
John Doe - 返信
コメントを追加
統計データを表示:
過去 24時間: 26
過去 7 日: 128
過去 30 日: 534
今までの合計 49,411
