この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Although the Roccat Kone[+] represents Roccat's top of the line model in gaming mice category, it has one small weakness within the scroll wheel mechanism. It is very sensite to dust...and after some time it will start to malfunction
In this video you will find a short review of the Kone[+] and the manifestation of the glitch.
Before you atempt to perform this repair make sure the glicth is actually permanent, and make an attempt at fixing it with a few blows with an air compressor.
必要な工具と部品
Unplug mouse.
Cover the optical sensor with tape
With a heat gun/hair dryer start warming up the covers. This serves to loosen up the glue that keeps the glides attached to the mouse.
Once hot, try to gently lift the glide and work the edges. (to reapply it back on heat the gliders but not to hot to burn but to make the the glue soft, then firmly hold it in place till it cools and holds it grip.)
Once glidez are removed, screws are in plain sight
DO NOT TOUCH OR STAIN THE STICKY PART OF THE GLIDEZ, otherwise they will not stick back.
Unscrew all 4 screws.
Gently pull the lower and upper part in opposite directions. DO NOT USE FORCE.
Lower and upper part are attached by 5 wires
You can either leave them attached or unplug the wires using the tweezers
I prefered to separate the two parts for better handling of the lower part, where optical sensor and scroll sensor are located.
Now spray contact cleaner (ignore WD-40) directly in the space indicated in the picture. Scroll up a couple of times and scroll down a few times while spraying.
plug mouse in to PC, you can easily check in real time if it clears up persistent, or vanishes.
If this won't fix it, this probably means the scroll sensor is permanently damaged/defective. (RMA?)
34 の人々がこのガイドを完成させました。
21 件のコメント
####WARNING####
You better stick with the hair dryer when warming up the glue of the glidez.
I just performed this guide and it totally worked out. But I used a heat gun to warm up the mouse glidez. Due to the heat, the plastic that shapes the left mouse button, deformed a bit. The mouse is actually working normal, but you need a significant higher force to push the LMB now.
So be careful about the temperatures when warming the glidez.
Beside this fault of mine, the guide is perfect. Mouse wheel glitch is completely gone.
thx.
mmda81
Thanks for the suggestion, already corrected. :)
Excellent concise guide. Thank You!!!
brenogrady - 返信
