はじめに
The sensor that ROCCAT uses for their scroll wheels is very sensitive to dust, and after some time it may start to malfunction by failing to register scroll actions or even scrolling in the wrong direction.
In this video, you will find a short review of the Kone[+] and the manifestation of the glitch.
Before you attempt to perform this repair, make sure the glitch is permanent, and attempt to fix it with a few blows of compressed air.
必要な工具と部品
With a heat gun/hair dryer, warm up the covers. This will loosen up the glue that keeps the glider feet attached to the mouse.
Once hot, gently try to lift the gliders and work the edges.
Once the gliders are removed, the screws are easily visible
Turn the mouse back over and slowly lift off the top cover.
Use tweezers to disconnect the wires. If your model uses a ribbon cable, you will need to disengage the locking tab on the connector before pulling the cable out.
Spray electrical contact cleaner directly in the space indicated in the picture for several seconds, moving the scroll wheel back and forth as you spray.
34 の人々がこのガイドを完成させました。
21 件のコメント
####WARNING####
You better stick with the hair dryer when warming up the glue of the glidez.
I just performed this guide and it totally worked out. But I used a heat gun to warm up the mouse glidez. Due to the heat, the plastic that shapes the left mouse button, deformed a bit. The mouse is actually working normal, but you need a significant higher force to push the LMB now.
So be careful about the temperatures when warming the glidez.
Beside this fault of mine, the guide is perfect. Mouse wheel glitch is completely gone.
thx.
mmda81
Thanks for the suggestion, already corrected. :)
Excellent concise guide. Thank You!!!
brenogrady - 返信
