メインコンテンツにスキップ
Fixing Sound issues on your Kingston HyperX CloudX
必要な工具と部品
  1. Fixing Sound issues on your Kingston HyperX CloudX, Remove the Microphone: 手順 1、 1の画像 1
    • Remove the microphone from the left side of the headphones.
    • The microphone is removeable from the headphones themselves and does not require any disassembly
  2. Fixing Sound issues on your Kingston HyperX CloudX, Remove the Memory Foam: 手順 2、 3の画像 1 Fixing Sound issues on your Kingston HyperX CloudX, Remove the Memory Foam: 手順 2、 3の画像 2 Fixing Sound issues on your Kingston HyperX CloudX, Remove the Memory Foam: 手順 2、 3の画像 3
    • Remove the memory foam from the side of the headphones that are giving the audio problem
    • Both sides come off easily! All you have to do is pull the memory foam from the headset and it should come right off.
  3. Fixing Sound issues on your Kingston HyperX CloudX, Unscrew the headphones: 手順 3、 3の画像 1 Fixing Sound issues on your Kingston HyperX CloudX, Unscrew the headphones: 手順 3、 3の画像 2 Fixing Sound issues on your Kingston HyperX CloudX, Unscrew the headphones: 手順 3、 3の画像 3
    • Remove the four 5.0 mm screws located under each memory foam using a Phillips #1 screwdriver.
    • Make sure to hold onto the screws, as you will need them to put the headset back together.
  4. Fixing Sound issues on your Kingston HyperX CloudX, Look for any missing/Broken wires: 手順 4、 2の画像 1 Fixing Sound issues on your Kingston HyperX CloudX, Look for any missing/Broken wires: 手順 4、 2の画像 2
    • Look for wires that are missing from the circuit board.
    • For this repair, our headset was missing a green wire so we will solder that back to the board
  5. Fixing Sound issues on your Kingston HyperX CloudX, Solder the missing wire: 手順 5、 1の画像 1
    • Solder the missing wire back to the headphone's circuit board
終わりに
作成者
3人の作成者と共同で作成されました。
Brendan Hopkins
メンバー登録日: 10/08/19
133 ポイント
1ガイドが承認済み
チーム
Eastern Washington University, Team S27-G9, Munoz Fall 2019 Eastern Washington University, Team S27-G9, Munoz Fall 2019人のメンバー
EWU-MUNOZ-F19S27G9
1 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 6
過去 30 日: 33
今までの合計 2,347
