メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
はじめに
This guide shows how to repair a paper jam. This process requires no necessary tools or knowledge of the device.
  1. The paper indicator light blinks red if a paper jam occurs. It might have an unusual clicking noise. Press paper button to eject paper.
    • The paper indicator light blinks red if a paper jam occurs. It might have an unusual clicking noise.
    • Press paper button to eject paper.
    • If previous step does not work, turn off the printer and proceed to step 2. Else, proceed to step 4.
  2. Attempt to remove paper by gently and slowly pulling the paper out from the top.
    • Attempt to remove paper by gently and slowly pulling the paper out from the top.
    • Pull the paper as straight as possible.
    • If this does not work, proceed to step 3. Else, proceed to step 4.
  3. Nintendo Switch 修理キット
    ゲームを再開するための、早くて簡単な修理キット
    Switch 修理キットページへ
    Switch 修理キットページへ
  4. Open cover of the printer. Gently pull out the paper through the hatch. If ink cartridge is in the way, gently push it off to the side.
    • Open cover of the printer.
    • Gently pull out the paper through the hatch.
    • If ink cartridge is in the way, gently push it off to the side.
    • Close cover.
  5. If you had success in step 1, paper indicator light should now return to the normal color green.
    • If you had success in step 1, paper indicator light should now return to the normal color green.
    • If you had success in step 2 or 3, turn on printer and press paper button.
終わりに
2 の人々がこのガイドを完成させました。
Xin Chen
メンバー登録日: 2011年10月12日
922 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 17-11, Regan Fall 2011 Cal Poly, Team 17-11, Regan Fall 2011人のメンバー
CPSU-REGAN-F11S17G11
4 メンバー
6のガイドは作成済み
2 件のコメント
hi my printer(1400) won't print anything whenever I try to print it stacks and then two lights starts blinking on the computer it's saying fetal error paper jam please help me
nkumbu namukoko - 返信
My machine is Epson 1500w ,it make an unusual noise when printing to the middle of the paper and stop lwith the red light blinkinig. Please I need heklp
stephen Banguu-Wobnyine - 返信
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 19
今までの合計 5,949
