ツール
工具は必要ありません。
パーツ
パーツは必要ありません。
  1. Put the device in front of you, with the knob labels the right side up
    • Put the device in front of you, with the knob labels the right side up
  2. Pry the rubber off the top of the device All the rubber
    • Pry the rubber off the top of the device
    • All the rubber
    • Use your fingernails, then pull with your bare hands. Do no use a heat gun or prying tool as they will damage the adhesive.
    • 5 screw holes will appear. Leave them alone for now.
  3. Look at the side of the device with the metal stand Take a heat gun to the two small foam pads
    • Look at the side of the device with the metal stand
    • Take a heat gun to the two small foam pads
    • You only need to pry off the halves on the top plastic shell
    • Put scraps of glossy paper on the foam pads to prevent them from sticking on again
    • Alternatively, if you do not mind sacrificing aesthetics, you may slice the foam pads down the middle as in the picture.
  4. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  5. Now remove the 5 Philips screws on top Now remove the 5 Philips screws on top
    • Now remove the 5 Philips screws on top
  6. Simply lift off the top
    • Simply lift off the top
    • No clips anywhere
  7. You could now lift out the whole innards
    • You could now lift out the whole innards
    • They are not attached to the bottom shell
    • No, the mess of glue is how it left the factory
  8. Look for a small metal rectangle with a hole
    • Look for a small metal rectangle with a hole
    • It's supposed to give a Kensington lock a better hold than the thin backplate
    • It's insufficiently glued on
まとめ
Tobias
メンバー登録日: 2014年07月24日
10 ポイント
2のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 173
