必要な工具と部品
ビデオの概要
The iPhone X has been dropped and can’t work normally. After restoring, the phone can’t be activated. Next, we try to activate the phone with 3uTools.
Connect the phone to the computer and open 3uTools. Click Activate Now and Start.
The activation normally takes several minutes. After about 20 minutes, the phone is stuck in the activation interface. The phone is still unable to be activated.
Apply some Solder Paste to the missing pads and apply tin with Hot Air Gun at 340 °C. Clean the bonding pad with PCB Cleaner and apply some Paste Flux.
Solder 0.02 mm copper wires to the bonding pad with Soldering Iron. Please be noted that copper wires must be soldered firmly.
Clean with PCB Cleaner again and curl the copper wires to make pads with Tweezers and Sculpture Knife.
Apply Solder Mask to the bonding pad to fix the copper wires and solidify the solder mask with UV Lamp for 5 minutes.
Scrape away excess solder mask with Sculpture Knife to show the copper wires.
Next, remove tin on the bonding pad with Soldering Iron at 365 °C and Solder Wick. Clean the bonding pad with PCB Cleaner.
Put the motherboard on the 165 °C Heating Platform to heat.
After the solder balls are formed, turn the power off and cool the signal board. Apply some Paste Flux and align the logic board with the signal board.
Keep heating for 1 minute when the temperature reaches 165 °C. Turn the power off and cool the motherboard.
2 の人々がこのガイドを完成させました。
