メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
The ambient light sensor of iPhone 8/8 Plus/X stops working after third-party screen repairs. After the issue was properly exposed, solution for it has been a hot topic for the industry. Here is a solution for iPhone ALS issues.
ビデオの概要
  1. Normal 3D Touch and touch function. Run ambient light sensor test. The phone can adjust brightness automatically.
    • Normal 3D Touch and touch function. Run ambient light sensor test. The phone can adjust brightness automatically.
  2. Take apart the phone and remove the original screen. Get a replacement screen installed and test.
    • Take apart the phone and remove the original screen. Get a replacement screen installed and test.
    • Normal 3D Touch and touch function. Run ambient light sensor test. The phone loses its functionality to automatically adjust brightness.
  3. 今あるものを使い続けましょう
    オールインワインキットで安く修理して、節約しましょう。
    iPhone 修理キットを見る
    今あるものを使い続けましょう
    iPhone 修理キットを見る
  4. Connect the original screen to the ALS programmer. Then the replacement screen.
    • Connect the original screen to the ALS programmer. Then the replacement screen.
    • Press‘Read’ button to read data of the original screen. Then press ‘Write’ button to burn data of the original screen onto the replacement screen.
  5. Get the replacement screen installed and turn on the phone. Run 3D Touch and touch function test. All going well. Run ambient light sensor test. The phone can adjust brightness automatically.
    • Get the replacement screen installed and turn on the phone. Run 3D Touch and touch function test. All going well. Run ambient light sensor test. The phone can adjust brightness automatically.
ある他の人がこのガイドを完成しました。
Phryne
メンバー登録日: 2019年11月17日
10,181 ポイント
80のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 1
過去 7 日: 19
過去 30 日: 105
今までの合計 105
