メインコンテンツにスキップ
Fix a Loose Mounting Dream MD2462 TV Wall Mount
必要な工具と部品
  1. Fix a Loose Mounting Dream MD2462 TV Wall Mount, Fix a Loose Mounting Dream MD2462 TV Wall Mount: 手順 1、 3の画像 1 Fix a Loose Mounting Dream MD2462 TV Wall Mount, Fix a Loose Mounting Dream MD2462 TV Wall Mount: 手順 1、 3の画像 2 Fix a Loose Mounting Dream MD2462 TV Wall Mount, Fix a Loose Mounting Dream MD2462 TV Wall Mount: 手順 1、 3の画像 3
    • Remove the two M4x5mm bolts on the back of the TV plate using a Phillips #00 screwdriver.
    • Unplug the TV cables before removing the TV from the wall.
  2. Fix a Loose Mounting Dream MD2462 TV Wall Mount: 手順 2、 3の画像 1 Fix a Loose Mounting Dream MD2462 TV Wall Mount: 手順 2、 3の画像 2 Fix a Loose Mounting Dream MD2462 TV Wall Mount: 手順 2、 3の画像 3
    • Remove the three lag bolts from the wall mount by using a 13mm open-end wrench.
    • If it is too loose, it can just be pulled out.
  3. Fix a Loose Mounting Dream MD2462 TV Wall Mount: 手順 3、 3の画像 1 Fix a Loose Mounting Dream MD2462 TV Wall Mount: 手順 3、 3の画像 2 Fix a Loose Mounting Dream MD2462 TV Wall Mount: 手順 3、 3の画像 3
    • Fill the holes where the screws were secured using drywall spackle.
  4. Fix a Loose Mounting Dream MD2462 TV Wall Mount: 手順 4、 1の画像 1
    • Locate the wooden studs on the wall using a stud finder or knock on the wall to see if the stud is behind the wall.
  5. Fix a Loose Mounting Dream MD2462 TV Wall Mount: 手順 5、 3の画像 1 Fix a Loose Mounting Dream MD2462 TV Wall Mount: 手順 5、 3の画像 2 Fix a Loose Mounting Dream MD2462 TV Wall Mount: 手順 5、 3の画像 3
    • Use a pencil to mark three holes on the wall.
    • Use a 3/8-inch drill bit to drill three holes at the marked positions.
    • Secure the wall mount into the wooden studs using new screws or bolts.
    • Ensure that all the screws are firmly secured to the wooden stud.
  6. Fix a Loose Mounting Dream MD2462 TV Wall Mount: 手順 6、 2の画像 1 Fix a Loose Mounting Dream MD2462 TV Wall Mount: 手順 6、 2の画像 2
    • Test the firmness of the TV wall mount by gently pushing it up and down.
  7. Fix a Loose Mounting Dream MD2462 TV Wall Mount: 手順 7、 2の画像 1 Fix a Loose Mounting Dream MD2462 TV Wall Mount: 手順 7、 2の画像 2
    • Gently replace the TV back on the wall mount.
  8. Fix a Loose Mounting Dream MD2462 TV Wall Mount: 手順 8、 1の画像 1
    • Make sure the TV is secure and well-centered on the wall mount using a spirit level gauge to confirm the inclination.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Emmanuel Emedeke
メンバー登録日: 09/17/20
184 ポイント
1ガイドが承認済み
チーム
York University, Team S2-G6, Melo-Thaiss Fall 2020 York University, Team S2-G6, Melo-Thaiss Fall 2020人のメンバー
YORK-MELO-THAISS-F20S2G6
1 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 53
今までの合計 5,017
