メインコンテンツにスキップ
Fix NUC8i7BEH overheating
必要な工具と部品
  1. Fix NUC8i7BEH overheating, Turn NUC upside down: 手順 1、 3の画像 1 Fix NUC8i7BEH overheating, Turn NUC upside down: 手順 1、 3の画像 2 Fix NUC8i7BEH overheating, Turn NUC upside down: 手順 1、 3の画像 3
    • Place the NUC upside down and select a PH2 Phillips screw driver bit
  2. Fix NUC8i7BEH overheating, Unscrew lower lid: 手順 2、 2の画像 1 Fix NUC8i7BEH overheating, Unscrew lower lid: 手順 2、 2の画像 2
    • Start by using a Phillips head #2 screw driver to remove the lower screws on the lower case door.
    • These screws are held in with retainers, so they won't fall out when you flip the lid.
  3. Fix NUC8i7BEH overheating, Lid and HDD Bracket: 手順 3、 3の画像 1 Fix NUC8i7BEH overheating, Lid and HDD Bracket: 手順 3、 3の画像 2 Fix NUC8i7BEH overheating, Lid and HDD Bracket: 手順 3、 3の画像 3
    • Lift the door, and keep an eye on the cables that connect to the NUC's motherboard. These cables are the power and data cables for the 2.5" hard drive bay.
    • Carefully unplug the cables from the motherboard, and set the bracket aside.
    • In the last photo, the slot for a blade SSD is marked with a red arrow. This is where you would install the blade SSD, and use a screw to hold it in place.
  4. Fix NUC8i7BEH overheating, SSD removal: 手順 4、 2の画像 1 Fix NUC8i7BEH overheating, SSD removal: 手順 4、 2の画像 2
    • Change the screw driver bit to the PH1 one.
    • Unscrew the V-NAND SSD and carefully slide it out of its connector.
    • Previous step as video
  5. Fix NUC8i7BEH overheating, Motherboard Removal (Screw driver): 手順 6、 1の画像 1
    • Change the screw driver bit to PH1
  6. Fix NUC8i7BEH overheating, Motherboard Removal: 手順 7、 3の画像 1 Fix NUC8i7BEH overheating, Motherboard Removal: 手順 7、 3の画像 2 Fix NUC8i7BEH overheating, Motherboard Removal: 手順 7、 3の画像 3
    • Unscrew the screws marked in red circles
  7. Fix NUC8i7BEH overheating, Motherboard Removal, continued.: 手順 8、 3の画像 1 Fix NUC8i7BEH overheating, Motherboard Removal, continued.: 手順 8、 3の画像 2 Fix NUC8i7BEH overheating, Motherboard Removal, continued.: 手順 8、 3の画像 3
    • Remove the WiFi and Bluetooth antenna cables (be extremely careful when doing this otherwise you risk to rip the base contact terminal off the PCB)
    • Remove the stereo mic cable from the motherboard connector.
    • Pay attetion to the WiFi cable hidden under a black piece of tape
    • Disconnect mic cable
    • Remove padders from the sides
  8. Fix NUC8i7BEH overheating, Remove protection padding, continued: 手順 11、 2の画像 1 Fix NUC8i7BEH overheating, Remove protection padding, continued: 手順 11、 2の画像 2
    • Not all are necessary only the two depicted.
  9. Fix NUC8i7BEH overheating, Motherboard Removal, final step: 手順 12、 3の画像 1 Fix NUC8i7BEH overheating, Motherboard Removal, final step: 手順 12、 3の画像 2 Fix NUC8i7BEH overheating, Motherboard Removal, final step: 手順 12、 3の画像 3
    • Use a pry tool to lift the motherboard from the casing
    • Marked with red circles the dust signs evident on first sight
  10. Fix NUC8i7BEH overheating, Remove CPU fan: 手順 13、 3の画像 1 Fix NUC8i7BEH overheating, Remove CPU fan: 手順 13、 3の画像 2 Fix NUC8i7BEH overheating, Remove CPU fan: 手順 13、 3の画像 3
    • Remove the 3 screws fixing the CPU fan
    • Remove the fan power connect from the motherboard
  11. Fix NUC8i7BEH overheating, Blast off dust from CPU air exit fins: 手順 14、 3の画像 1 Fix NUC8i7BEH overheating, Blast off dust from CPU air exit fins: 手順 14、 3の画像 2 Fix NUC8i7BEH overheating, Blast off dust from CPU air exit fins: 手順 14、 3の画像 3
    • You will need to use compressed air, a small vacuum cleaner or something similar to blast off all the stucked dust.
  12. Fix NUC8i7BEH overheating, Blast off dust from CPU air exit fins, continued: 手順 15、 1の画像 1
    • I'm using a compressed air can (optional)
    • Video of the procedure
  13. Fix NUC8i7BEH overheating, Exchange thermal paste for CPU cooler (optional): 手順 18、 2の画像 1 Fix NUC8i7BEH overheating, Exchange thermal paste for CPU cooler (optional): 手順 18、 2の画像 2
    • This step is probably not necessary, but for the sake of completeness here it is.
    • Remove the screws holding the CPU cooler following the numbers on them.
  14. Fix NUC8i7BEH overheating, Clean old CPU thermal paste: 手順 19、 3の画像 1 Fix NUC8i7BEH overheating, Clean old CPU thermal paste: 手順 19、 3の画像 2 Fix NUC8i7BEH overheating, Clean old CPU thermal paste: 手順 19、 3の画像 3
    • Use isopropyl alcohol for this, be careful not to touch the the thermal pads on the chips around the CPU.
  15. Fix NUC8i7BEH overheating, Reapply CPU thermal paste: 手順 20、 1の画像 1
    • Be careful not to apply too much of it.
終わりに
40 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Vladimir Knobel
メンバー登録日: 03/27/14
2,716 ポイント
2のガイドは作成済み
29 件のコメント
Very helpful, thank you!
Ray Wang - 返信
Great tutorial, thanks, now my fan is very clean and quiet. Thanks for spending time to create this guide!
Schüszterl Ferenc - 返信
I did see this guide after finding out the same steps myself and having seen this guide before doing so would be very helpful.
Jack Graus - 返信
Great tutorial. Clear pictures, solid instructions. Thanks a lot!
Koen Veys - 返信
you are welcome
Vladimir Knobel -
コメントを追加
統計データ:
過去 24時間: 43
過去 7 日: 203
過去 30 日: 1,019
今までの合計 43,729
