• First, determine if the problem is occurring due to water damage. To do that, look at the battery and see if the water indicator (red or blue) has been activated. If so, go to the next step.
    • Then, remove the battery from the phone.
    • Using a blow dryer, blow warm air on both the battery and the remainder of the device for about three minutes.
  1. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
    今まで、何かを修理したことがありますか?ジーニアスです。
    あなたのリペアストーリーを#ImAGenius でシェアしてください。
    私たちは皆んな、ジーニアスです。
    • Bring two zip lock bags and fill them with 2 cups of either salt or rice.
    • Put the battery in one of the two bags and put the rest of the device in the other one.
    • Close the bags well so that they are airtight. Then place the bags in a dark dry spot for about a week. Make sure to be patient because the process of evaporating moisture takes a very long time.
    • Wait one week. Retrieve the bags. Open the bags and reconnect the battery with the body of the Motorola Adventure V750. Though the moisture indicator may still say the battery is wet, connect the battery back to the device and continue to turn on the phone.
    • If problem still exists, consider purchasing new battery and installing it with the old device.
まとめ
ある他の人がこのガイドを完成しました。
Kyle
メンバー登録日: 2012年10月01日
572 ポイント
5のガイドは作成済み
チーム
University of Maine, Team 1-2, Diaz Fall 2012 University of Maine, Team 1-2, Diaz Fall 2012人のメンバー
UMAINE-DIAZ-F12S1G2
3 メンバー
5のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 309
