メインコンテンツにスキップ
Five Steps To Apply A New OCA On Samsung Galaxy Note 8 Edge Touch Glass
必要な工具と部品
ビデオの概要
  1. Five Steps To Apply A New OCA On Samsung Galaxy Note 8 Edge Touch Glass, Put a new OCA: 手順 1、 2の画像 1 Five Steps To Apply A New OCA On Samsung Galaxy Note 8 Edge Touch Glass, Put a new OCA: 手順 1、 2の画像 2
    • We put a new OCA on a new Samsung Galaxy Note 8 touch screen. It doesn’t paste on the touch screen because the protector of the OCA is no need to be torn off. And you can move the OCA around until you get the right place.
  2. Five Steps To Apply A New OCA On Samsung Galaxy Note 8 Edge Touch Glass, Using upper mold: 手順 2、 2の画像 1 Five Steps To Apply A New OCA On Samsung Galaxy Note 8 Edge Touch Glass, Using upper mold: 手順 2、 2の画像 2
    • Then we put the upper mold on the base one after we align the position and continue to press it with our hands.
    • At this moment, the OCA is absorbed on the upper mold.
  3. Five Steps To Apply A New OCA On Samsung Galaxy Note 8 Edge Touch Glass, Remove the protector of the OCA: 手順 3、 1の画像 1
    • Remove the protector of the OCA
  4. Five Steps To Apply A New OCA On Samsung Galaxy Note 8 Edge Touch Glass, Remove protector of the new touch screen: 手順 4、 1の画像 1
    • For this step, we can use an easy tape to tear off the protector of the touch screen.
  5. Five Steps To Apply A New OCA On Samsung Galaxy Note 8 Edge Touch Glass, Using lamination machine: 手順 5、 2の画像 1 Five Steps To Apply A New OCA On Samsung Galaxy Note 8 Edge Touch Glass, Using lamination machine: 手順 5、 2の画像 2
    • After finishing the above steps, we put the whole set of mold into RMB-2 Laminating Machine for bonding.
    • For the whole process, the vacuum time we set is 30s and the lamination time is 10s, the total time for the lamination only needs 40s.
    • Now let’s see the final result after the lamination. There is no any bubble on the touch screen and the OCA’s position is completely unbiased and exactly overlap with touch screen. So the lamination effect is excellent.
終わりに
Why we say this mold is so effective? As during the bonding or before the bonding, the protector of the OCA doesn’t need to be ripped off. It is very precise and accurate because you can move and align the position optionally until you get a best place.
4 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
FORWARD Lab
メンバー登録日: 04/17/20
1,504 ポイント
8のガイドは作成済み
2 件のコメント
Thanks for that useful informations……. Also visit
(https://rb.gy/hmx3oc)
Selma Dietheimer - 返信
thanks for your appreciate
FORWARD Lab -
コメントを追加
統計データ:
過去 24時間: 10
過去 7 日: 28
過去 30 日: 122
今までの合計 7,952
