メインコンテンツにスキップ
Fitbit Surge Touchscreen Sensor Replacement
必要な工具と部品
  1. Fitbit Surge Touchscreen Sensor Replacement, Touchscreen Sensor: 手順 1、 2の画像 1 Fitbit Surge Touchscreen Sensor Replacement, Touchscreen Sensor: 手順 1、 2の画像 2
    • Unscrew all four black 3 mm screws on the underside of the watch using a T5 screwdriver.
  2. Fitbit Surge Touchscreen Sensor Replacement: 手順 2、 3の画像 1 Fitbit Surge Touchscreen Sensor Replacement: 手順 2、 3の画像 2 Fitbit Surge Touchscreen Sensor Replacement: 手順 2、 3の画像 3
    • Use an X-Acto knife to cut the band above, on either side, and in between the 2 screws.
    • Note: Part of the band is hard plastic.
    • Caution: Once the band is cut it cannot be reattached.
  3. Fitbit Surge Touchscreen Sensor Replacement: 手順 3、 2の画像 1 Fitbit Surge Touchscreen Sensor Replacement: 手順 3、 2の画像 2
    • Scrape away the glue beneath the hard shell portion of the band to reveal the GPS.
  4. Fitbit Surge Touchscreen Sensor Replacement: 手順 4、 1の画像 1
    • Use a PH000 screw head to undo the newly revealed silver 4 mm Phillips screws that were hidden beneath the glue.
  5. Fitbit Surge Touchscreen Sensor Replacement: 手順 5、 2の画像 1 Fitbit Surge Touchscreen Sensor Replacement: 手順 5、 2の画像 2
    • Using a metal spudger, push down on the plastic gray square clamps on the underside of the device to dislodge the whole silver backing.
    • Note: the buttons will also come off.
  6. Fitbit Surge Touchscreen Sensor Replacement: 手順 6、 1の画像 1
    • Use a thin tool to pry the the device apart by lodging it between the clock face and back side of the device.
    • Note: A spudger may not be thin enough to fit in the seam of the device. We used the 6 inch metal ruler from the Pro Tech Toolkit.
  7. Fitbit Surge Touchscreen Sensor Replacement: 手順 7、 1の画像 1
    • Remove the touchscreen sensor using a spudger or your fingers.
    • Note: In this photo we removed the metal cover on the main PCB, but you do not need to remove it for this guide.
終わりに
To reassemble your device, follow these instructions in reverse order. Keep in mind that the wristband will need to be cut for this repair and it cannot be reattached.
7 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Angela Pitts
メンバー登録日: 10/11/16
1,190 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team 1-3, Leahy Fall 2016 USF Tampa, Team 1-3, Leahy Fall 2016人のメンバー
USFT-LEAHY-F16S1G3
3 メンバー
4のガイドは作成済み
5件のガイドコメント
Is there a company that will perform this fix for me?
Terry Brown - 返信
Where can I get a replacement sensor?
Francisco Cortez - 返信
Isn’t any step missing in that instruction ?
Removing sensor will solve the issue ? How about adding new one ?
Erazm Gondoresku - 返信
Hi, I didnt get the point, what should I do after removing sensor? Should I clean it or something? If I need to place a new one, maybe someone knows where to get one?
viktoras -
Is anyway I can buy the bus
Ajay Kumar - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 15
今までの合計 2,999
