メインコンテンツにスキップ
Fitbit Surge Battery Replacement
必要な工具と部品
  1. Fitbit Surge Battery Replacement, Battery: 手順 1、 2の画像 1 Fitbit Surge Battery Replacement, Battery: 手順 1、 2の画像 2
    • Unscrew all four black 3 mm Phillips screws on the underside of the watch using a T5 screwdriver.
  2. Fitbit Surge Battery Replacement: 手順 2、 3の画像 1 Fitbit Surge Battery Replacement: 手順 2、 3の画像 2 Fitbit Surge Battery Replacement: 手順 2、 3の画像 3
    • Use an X-Acto knife to cut the band above, on either side, and in between the 2 screws.
    • Note: Part of the band is hard plastic.
    • Caution: The band cannot be reattached once it is cut.
  3. Fitbit Surge Battery Replacement: 手順 3、 2の画像 1 Fitbit Surge Battery Replacement: 手順 3、 2の画像 2
    • Scrape away the glue beneath the hard shell portion of the band to reveal the GPS.
  4. Fitbit Surge Battery Replacement: 手順 4、 2の画像 1 Fitbit Surge Battery Replacement: 手順 4、 2の画像 2
    • Use a PH000 screw head to undo the newly revealed silver 4 mm Phillips screws that were hidden beneath the glue.
  5. Fitbit Surge Battery Replacement: 手順 5、 2の画像 1 Fitbit Surge Battery Replacement: 手順 5、 2の画像 2
    • Using a metal spudger, push down on the plastic gray square clamps on the underside of the device to dislodge the whole silver backing.
    • Note: the buttons will also come off.
  6. Fitbit Surge Battery Replacement: 手順 6、 1の画像 1
    • Use a pick or small flathead to remove the 4 metal clamps holding device together.
    • Use a thin tool to pry the the device apart by lodging it between the clock face and back side of the device.
    • Note: a spudger may not be thin enough to fit in the seam of the device. We used the 6 inch metal ruler from the Pro Tech Toolkit.
    • Go slowly and carefully disconnect two cables before fully opening.
  7. Fitbit Surge Battery Replacement: 手順 7、 1の画像 1
    • Gently remove the battery.
終わりに
To reassemble your device, follow these instructions in reverse order. Keep in mind that the band will need to be cut for this repair and it cannot be reattached.
11 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Angela Pitts
メンバー登録日: 10/11/16
1,187 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team 1-3, Leahy Fall 2016 USF Tampa, Team 1-3, Leahy Fall 2016人のメンバー
USFT-LEAHY-F16S1G3
3 メンバー
4のガイドは作成済み
10 件のコメント
I'm about to embark on replacing the battery for my fitbit surge. After having it for over 2 years it requires a charge about twice a day which get annoying.
Does removing/replacing the battery require the moderate soldering skill?
L “Rico” Hirano - 返信
Looks like it must.
Chaspsmith - 返信
The last photo I think shows the tool prying the force feedback motor, the battery is the white plastic covered slim brick on the top right.
csaba.toth.us - 返信
You do not need to cut bands off
Tim master - 返信
The replacement battery for the Fitbit Surge can be found here:
It also includes all of the tools (except soldering iron) needed for the repair.
michaelf33707 - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 28
今までの合計 19,897
