メインコンテンツにスキップ
Fitbit Surge Screen Replacement
必要な工具と部品
  1. Fitbit Surge  Screen Replacement, Screen: 手順 1、 2の画像 1 Fitbit Surge  Screen Replacement, Screen: 手順 1、 2の画像 2
    • Unscrew all four black 3 mm Phillips screws on the underside of the watch using a T5 screwdriver.
  2. Fitbit Surge  Screen Replacement: 手順 2、 3の画像 1 Fitbit Surge  Screen Replacement: 手順 2、 3の画像 2 Fitbit Surge  Screen Replacement: 手順 2、 3の画像 3
    • Use an X-Acto knife to cut the band above, on either side, and in between the 2 screws.
    • Note: Part of the band is hard plastic.
    • Caution: Once the band is cut it cannot be reattached.
  3. Fitbit Surge  Screen Replacement: 手順 3、 2の画像 1 Fitbit Surge  Screen Replacement: 手順 3、 2の画像 2
    • Scrape away the glue beneath the hard shell portion of the band to reveal the GPS.
  4. Fitbit Surge  Screen Replacement: 手順 4、 1の画像 1
    • Use a PH000 screw head to undo the newly revealed silver 4 mm Phillips screws that were hidden beneath the glue.
  5. Fitbit Surge  Screen Replacement: 手順 5、 2の画像 1 Fitbit Surge  Screen Replacement: 手順 5、 2の画像 2
    • Using a metal spudger, push down on the plastic gray square clamps on the underside of the device to dislodge the whole silver backing.
    • Note: the buttons will also come off.
  6. Fitbit Surge  Screen Replacement: 手順 6、 1の画像 1
    • Use a thin tool to pry the the device apart by lodging it between the clock face and back side of the device.
    • Note: A spudger may not be thin enough to fit in the seam of the device. We used the 6 inch metal ruler from the Pro Tech Toolkit.
  7. Fitbit Surge  Screen Replacement: 手順 7、 2の画像 1 Fitbit Surge  Screen Replacement: 手順 7、 2の画像 2
    • Remove the protective cover underneath the clock face, by unscrewing the three 2 mm Phillips screws using a PH000 screwdriver.
    • Lift the protective cover to remove it and reveal the device's screen.
  8. Fitbit Surge  Screen Replacement: 手順 8、 1の画像 1
    • Remove the LCD screen from the clock face.
終わりに
Please note that the band cannot be reattached as it must be cut in order to replace the screen.
5 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Angela Pitts
メンバー登録日: 10/11/16
1,190 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team 1-3, Leahy Fall 2016 USF Tampa, Team 1-3, Leahy Fall 2016人のメンバー
USFT-LEAHY-F16S1G3
3 メンバー
4のガイドは作成済み
7件のガイドコメント
Where do you purchase replacement screens?
rikconstr - 返信
Is the outer glass and screen two separate parts? If so where can I get the assembly for the outermost glass? Is the touchscreen portion of the watch the LCD itself or the outer screen? I have been searching endlessly for that part or directions on how to replace it.
Chris anderson - 返信
I took my apart because there was condensation under the touch screen. While doing this I found that there are several modifications to these steps.
1. Use a Philips PH00 as its a better fit.
2. Don’t cut the band. I was able to use a thin spudger to pry around it and get it off. If you do need to replace the band you can find one on Amazon.
3. Don’t scrape away the adhesive; you need that to re-attach the band. You may need to move some of it but you don't need to scrape it clean.
4. At step 5 I found it better to push in the single button and then pry the outer gray casing off. The buttons didn’t appear to remove after the casing was removed.
5. Before step 6: There are 4 clasps that are holding the top and bottom parts together. Those need to be removed before you can pry it open.
itgse - 返信
Also want to know where to buy the replacement screen or the glass ( if separate)
james - 返信
This is a nice advertisement for minture tools but we need to locate a source for replacement screens…….not screen protectors.
All the tools in the world are useless if you have no screen……no screen no need for tools.
So, where can replacement screens be sourced for the Fitbit Surge
canjockey - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 22
今までの合計 16,209
