メインコンテンツにスキップ
First-gen Honda Odyssey Oil and filter change
必要な工具と部品
  1. First-gen Honda Odyssey Oil and filter change, Oil and Oil filter: 手順 1、 1の画像 1
    • We'll be changing the oil and filter on my JDM-import 1999 Honda Odyssey with the 2.3L four-cylinder engine
  2. First-gen Honda Odyssey Oil and filter change, Jacking up the vehicle: 手順 2、 2の画像 1 First-gen Honda Odyssey Oil and filter change, Jacking up the vehicle: 手順 2、 2の画像 2
    • Thankfully this car has a centre lift point at the front of the subframe at the tow-hook
    • I just used the normal pinch welds to put the jack-stands under
  3. First-gen Honda Odyssey Oil and filter change: 手順 3、 2の画像 1 First-gen Honda Odyssey Oil and filter change: 手順 3、 2の画像 2
    • Open up the bonnet/hood for more light under the vehicle
    • I like to use cardboard to climb under the car
  4. First-gen Honda Odyssey Oil and filter change, Drain the oil pan: 手順 4、 3の画像 1 First-gen Honda Odyssey Oil and filter change, Drain the oil pan: 手順 4、 3の画像 2 First-gen Honda Odyssey Oil and filter change, Drain the oil pan: 手順 4、 3の画像 3
    • Position your drain pan, the drain bolt faces towards the rear of the oilpan
    • On this 1999 Odyssey it was a 23mm drain bolt
  5. First-gen Honda Odyssey Oil and filter change, Remove old oil filter: 手順 5、 3の画像 1 First-gen Honda Odyssey Oil and filter change, Remove old oil filter: 手順 5、 3の画像 2 First-gen Honda Odyssey Oil and filter change, Remove old oil filter: 手順 5、 3の画像 3
    • One of the hardest parts of this procedure
    • Honda put the oil filter mounting on the back of the engine block under the intake manifold
    • You have to reach past the subframe, exhaust, and axle
    • I like to use oil-filter pliers, but there are a few different tools that can be used
    • Check to make sure the gasket came off with the old filter and did not get left behind on the block
  6. First-gen Honda Odyssey Oil and filter change, Install a new oil filter: 手順 6、 3の画像 1 First-gen Honda Odyssey Oil and filter change, Install a new oil filter: 手順 6、 3の画像 2 First-gen Honda Odyssey Oil and filter change, Install a new oil filter: 手順 6、 3の画像 3
    • I used a JS Asakashi C-307J, (made in Japan)
    • I can order them shipped from Singapore cheaper then I can buy locally from Repco or Supercheap here in New Zealand
    • Oil up the gasket on the new filter
    • Clean the mounting plate on the block with your rags
  7. First-gen Honda Odyssey Oil and filter change, Check your work: 手順 7、 1の画像 1
    • If you've not already, put the drain bolt back in
    • Tighten the new oil filter 3/4 of a turn after it touches the block
    • Tighten the drain bolt without breaking it off :)
    • Clean around the filter and bolt with a rag so you can see any leaks
  8. First-gen Honda Odyssey Oil and filter change, Lower the car: 手順 8、 2の画像 1 First-gen Honda Odyssey Oil and filter change, Lower the car: 手順 8、 2の画像 2
    • Remove your cardboard and tools
    • Lift the car again from the centre lift point with your hydraulic jack
    • Pull the jack-stands out from each side
    • Carefully lower the car to the ground, leveling it for filling
  9. First-gen Honda Odyssey Oil and filter change, Fill the car: 手順 9、 1の画像 1
    • In the photo, the red circle is the oil fill point, and the yellow circle is the dipstick
    • I used Nulon 10W-40 full synthetic
    • I needed about 4.5L or so to fill
    • I like to use a stubby wide-mouth funnel
    • Pour large oil bottles sideways to reduce the blub-blub effect
  10. First-gen Honda Odyssey Oil and filter change, Check for leaks and re-check level: 手順 10、 2の画像 1 First-gen Honda Odyssey Oil and filter change, Check for leaks and re-check level: 手順 10、 2の画像 2
    • Run the engine for about 10 seconds to fill up the filter and oil galleys
    • Turn the engine off and check for leaks
    • Check the level using the dipstick and a rag again, it should have gone down a bit due to the oil filter filling up
    • Top up the level to the upper range of the dipstick
終わりに
Servicing done!
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Gaspard Leon
メンバー登録日: 04/24/10
2,840 ポイント
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 12
過去 30 日: 43
今までの合計 3,642
