メインコンテンツにスキップ
First Alert Smoke Alarm 9120B Battery Replacement
必要な工具と部品
  1. First Alert Smoke Alarm 9120B Battery Replacement, Battery: 手順 1、 3の画像 1 First Alert Smoke Alarm 9120B Battery Replacement, Battery: 手順 1、 3の画像 2 First Alert Smoke Alarm 9120B Battery Replacement, Battery: 手順 1、 3の画像 3
    • Remove the alarm by rotating it counter clockwise in the mount.
    • The alarm should fall off once rotated enough. The cable should be the only thing holding it in place if done correctly.
  2. First Alert Smoke Alarm 9120B Battery Replacement: 手順 2、 2の画像 1 First Alert Smoke Alarm 9120B Battery Replacement: 手順 2、 2の画像 2
    • Unplug the cable from the alarm.
  3. First Alert Smoke Alarm 9120B Battery Replacement: 手順 3、 3の画像 1 First Alert Smoke Alarm 9120B Battery Replacement: 手順 3、 3の画像 2 First Alert Smoke Alarm 9120B Battery Replacement: 手順 3、 3の画像 3
    • Press down on the catch on the top left of the alarm to open the battery compartment.
  4. First Alert Smoke Alarm 9120B Battery Replacement: 手順 4、 2の画像 1 First Alert Smoke Alarm 9120B Battery Replacement: 手順 4、 2の画像 2
    • Remove the battery and dispose of it properly.
    • Replace the old battery with a new 9V battery and close the compartment.
    • You should hear a click to know that the compartment is secured.
  5. First Alert Smoke Alarm 9120B Battery Replacement: 手順 5、 2の画像 1 First Alert Smoke Alarm 9120B Battery Replacement: 手順 5、 2の画像 2
    • Line up the holes of the cable on the mount with the pins on the alarm.
    • Reconnect the cable on the mount to that on the alarm.
    • It should insert itself with minimal force.
  6. First Alert Smoke Alarm 9120B Battery Replacement: 手順 6、 2の画像 1 First Alert Smoke Alarm 9120B Battery Replacement: 手順 6、 2の画像 2
    • Press the alarm into the mount.
  7. First Alert Smoke Alarm 9120B Battery Replacement: 手順 7、 3の画像 1 First Alert Smoke Alarm 9120B Battery Replacement: 手順 7、 3の画像 2 First Alert Smoke Alarm 9120B Battery Replacement: 手順 7、 3の画像 3
    • Rotate the alarm clockwise until it does not turn anymore. This makes sure the alarm is secured.
ゴール
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Miggy Reyes
メンバー登録日: 02/15/21
219 ポイント
1ガイドが承認済み
チーム
Texas Tech, Team S3-G17, Cowan Spring 2021 Texas Tech, Team S3-G17, Cowan Spring 2021人のメンバー
TTU-COWAN-S21S3G17
1 メンバー
3のガイドは作成済み
5 件のコメント
How do I disconnect the cable? Seems very tight and cannot disconnect.
Jeanne O - 返信
This is related to first alert smoke alarm 9120B. Can not remove connecting cable from alarm. Is very tight. So unable to change battery. Any suggestions?
Jeanne O - 返信
These alarms suck! Pressing the tab and the battery compartment does NOT pop open. I needed a knife to pry it open, and then it had to be forced close. NOT user error! The plastic pins that hold the battery compartment closed don't move out of the way enough to allow opening.
James Durso - 返信
I replaced the battery and it is still beeping, reset the smoke alarm. What should I do now?
Donald Sandford - 返信
Buy and install a new alarm. It’s easier than trying to fix on.
Stephen Taylor - 返信
コメントを追加
統計データ:
過去 24時間: 31
過去 7 日: 224
過去 30 日: 1,017
今までの合計 30,904
