メインコンテンツにスキップ
Firmware update or recovery - PC (All models)
必要な工具と部品
  1. Firmware update or recovery - PC (All models), Plug the controller in: 手順 1、 1の画像 1
    • Connect the controller using a USB-C OR MicroUSB cable. Plug the controller into a USB port on your PC.
    • Bluetooth firmware updates are not supported.
  2. Firmware update or recovery - PC (All models), Download the Xbox Accessories app.: 手順 2、 2の画像 1 Firmware update or recovery - PC (All models), Download the Xbox Accessories app.: 手順 2、 2の画像 2
    • Download the Xbox Accessories app from Microsoft Store using this link.
    • After it has finished downloading, you can launch it either straight off the app's page or from your Start Menu.
  3. Firmware update or recovery - PC (All models), Prepare the app for the firmware update: 手順 3、 2の画像 1 Firmware update or recovery - PC (All models), Prepare the app for the firmware update: 手順 3、 2の画像 2
    • After you launch the app and it finishes loading, the controller should show up like on the first photo.
    • Click on the three dots under the Configure button.
    • If the button over the Buzz/Vibrate this controller says No update available, your controller is already up to date and the guide ends here.
  4. Firmware update or recovery - PC (All models), Update the firmware: 手順 4、 2の画像 1 Firmware update or recovery - PC (All models), Update the firmware: 手順 4、 2の画像 2
    • Press the Continue button and wait for the process to finish.
    • In most cases, the firmware can be recovered, but be careful not to disconnect the controller during the update. Any loss of connection, be it disconnecting or PC power loss may damage the controller beyond repair.
    • After the update, press Close. Your controller is now up to date and should be fully usable with your PC, Xbox One or Series S/X consoles.
ゴール
6 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
SojerManLan
メンバー登録日: 07/07/21
253 ポイント
1ガイドが承認済み
1件のガイドコメント
Use this video if you need to undo anything.
Revert Firmware
go away - 返信
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 26
過去 30 日: 113
今までの合計 5,992
