メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Finding Model Name
  1. Finding Model Name, Finding Model Name: 手順 1、 2の画像 1 Finding Model Name, Finding Model Name: 手順 1、 2の画像 2
    • Check the exterior of the laptop for a sticker with the model name on it. This sticker may be underneath the battery, or on the underside of the battery, so you have to remove the battery to see it.
    • Use the (Win+R) key combination to open the Run... dialog. Type "control panel" (with no quotation marks) into this box to open the control panel. Click "System and Security", then click "System". Look for a model name here.
    • DirectX diagnostic tool: Press (Win+R). The "Run" dialog will appear. Type “dxdiag” (with no quotes) into this box and click OK. The “DirectX Diagnostic Tool” window will appear. Click on the “System” page and look for a “System Model” entry.
    • Command prompt: Press (Win-R). The "Run" window should appear. Type “cmd” (with no quotes) into this box and click OK. Command Prompt should appear. Type the following into the Command Prompt window, but with no quotation marks: “wmic csproduct get name”. Press the enter key and your model name should appear.
    • Sometimes the model name is printed or labelled on the computer’s motherboard. It is beyond the scope of this guide to explain how to access the motherboard, but this guide may be helpful.
ゴール
作成者
2人の作成者と共同で作成されました。
Tim Cedar
メンバー登録日: 09/28/18
934 ポイント
7のガイドは作成済み
チーム
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 39
今までの合計 344
